The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 31st May 2012, 07:01 PM   #5921
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by scott wurcer View Post
Yes, if I recall a Motrola Gilbert cell mixer and many carbon comp resistors were involved to make a very bad multiplier.
I didn't lift the hood, but a composer/professor friend bought one and was entranced with the marketing spiel, buying it hook, line, and sinker, and going on about how much better it was than some mere noise reduction scheme described in a more orthodox fashion.
Old 31st May 2012, 07:12 PM   #5922
a.wayne is offline a.wayne  United States
Sin Bin
I was one who used to scoff at Carver's products, started in the 70's when his PL stuff would lose it's output stage at a Whim ...
This perception never changed when he came out with his power cube's , always felt the man gimmicky at best, until ...! A close friend , a die hard Carver fan if there ever was one, brought over one of his Carver amplifiers, model escapes me , but it had 2 round meters and damn it , sent my ML-9 packing ..
Then there was his Sunfire deal , that one sent a BAT VK500 packing, I can honestly say , the man maybe the most underrated designer HEEEVAR !!!
I will surely give these a listen when the opportunity arises ...
Old 31st May 2012, 07:14 PM   #5923
On Hiatus
SY's Avatar
Don't forget his loudspeaker concepts which were really new and inspired a lot of copycats.
Disclaimer: I use Sunfire amps on my subwoofers, one of the very few pieces of stock commercial equipment in my system.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st May 2012, 07:16 PM   #5924
Sin Bin
His Sunfire amplifiers have really good sonics and drive, anyone care to explain his down converter Deal ...?
Old 31st May 2012, 07:18 PM   #5925
john curl is online now john curl  United States
john curl's Avatar
Scott, I can't hear through double-blind, when conditions are matched up the way they are supposed to be, like: level, polarity, and frequency response, so I think that the NULL results (I can't tell the difference) show that the test is FLAWED. This is because my ability to discriminate between otherwise 'identical' designs, returns when I can KEEP TRACK of the different designs while the music changes. NOT the specific IDENTITY of the compared designs, but the consistency of knowing which design is being listened to in the test. I decided about 1/3 of a century ago, AFTER trying ABX testing, that there was something wrong, AND that it would not give me any meaningful feedback. Since then, I designed the JC-80, Ultramaster (30 ips mastering recorder), Vendetta Research, CTC Blowtorch, etc, etc. You can't intimidate me into considering double blind testing as necessary or EVEN useful.
"Condemnation without Examination is Prejudice"
Old 31st May 2012, 09:27 PM   #5926
spladski is offline spladski  United Kingdom
Many blind tests are logically flawed. The tests can only have value if the parameters are very narrow and also tests for opposites can be implemented. I.E. artifact present not present.
A good example of a flawed test is the typical one to determine hearing bandwidth. A sweep of a sine wave which showed failure to hear a 20Khz tone as proof that the typical limit is 20Khz has a logical flaw. It can also be proven repeatedly and transferrably that this is not the case with a simple test that anyone can do.
Old 31st May 2012, 09:27 PM   #5927
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Amazing reasoning, if even in relaxed casual long term (but DB) listening I can't tell the difference I should still believe that there has to be one? Sounds like religious faith to me.
I remain more interested in preference where the difference is obvious.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 31st May 2012, 09:38 PM   #5928
On Hiatus
SY's Avatar
I think you're propping up a strawman. It's terrifically easy to create two wav files with whatever source material you like, one with a 20kHz filter (your example), one without (having only the 96kHz filter needed for 192k sample rate), then ABX them in your own system with foobar. If you can hear the difference reliably, great. I've used the foobar plugin to convince myself that I can hear all sorts of signal processing, though I'll admit that I absolutely could not distinguish between 24/96 and 16/44 versions of the same high res recording played at a normal level. But my ears are old, so...
Old 31st May 2012, 09:42 PM   #5929
Choose a signal with infinite bandwidth, then bandwidth limit it.
Old 31st May 2012, 09:43 PM   #5930
On Hiatus
SY's Avatar
Where do I get one of those infinite bandwidth mikes?
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
