The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 20th April 2012, 12:30 AM   #4511
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by a.wayne View Post
I had a similar conversation with Mr Audio Note some 15 + yrs ago and he was of the same mindset , that first watt got all of his focus ...
You have to take inflation into account.
The Devil is not so terrible as his math model is!
Old 20th April 2012, 12:30 AM   #4512
bcarso is offline bcarso  United States
diyAudio Member RIP
NO , it's B&K audio .... They made amplifiers , et al .......
OH. As Emily Latella would say, That's very different then.
Old 20th April 2012, 12:36 AM   #4513
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by bcarso View Post
Yep ---what do you find discrepant? The claim is 8.9% distortion (excluding noise as I read him) at a milliwatt, unspecified (but presumably larger) at 1 uW, again excluding noise.
My error you stated 82db below .....
Old 20th April 2012, 12:41 AM   #4514
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
"My name is Steve Keiser, the 'K' of B&K components, and presently design engineer with Luminance Audio. I have developed a measurement system which is able to quantify distortion levels at micropower quantities down to 1/1000th of a watt.
1mW is -50dB wrt full output of a typical 100W amplifier. Not particularly low level - D/A converter chips are normally characterized at -60dB wrt FS.
These measurement techniques are unprecedented, and have revealed a number of revelations of amplifier distortion characteristics, at micropower levels, which are in direct opposition with traditional and scientific assumptions up unto this point.
Unless he's not telling us something vital, its hardly 'unprecdented' to measure THD at -60dB for DACs, so what makes it so for amps?
The emphasis of my work is to definitively quantify low level signal linearity measurements of power amplifiers, and attempt to correlate these measurements with subjective listening results, as well as establishing the significance of low level distortion. Conventional test equipment generally does not resolve meaningful distortion measurements below 100mw, since the measurements become predominated by noise.
Conventional test equipment in the world of audio means AP, that has had this capability ever since the dual domain AP1 which is a couple of decades old now. The DAC manufacturers routinely use AP to show the distortion performance of their chips (with -60dBFS stimulus signal) down to -140dB or so.
To give you an example: the Halcro DM58 amplifier measures .007%THD at 2 watts, whereas at 1/1000th watts, THD measures 8.9%!
That does sound like an astonishingly poor result. The Halcro is nominally 200W so 1mW is -53dB and the THD is around -74dB? Stereophile shows the performance at 157W output, its noise-dominated at 0.0006%. Its jolly hard to believe therefore that the stated 0.007% @ 2W is correct as it would imply that the distortion harmonics rise as the stimulus goes down in level. Even relatively poor digital systems manage to keep them roughly the same under those conditions.
What am I missing?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 20th April 2012, 01:19 AM   #4515
tvrgeek is offline tvrgeek  United States
B& K is out of Business , he is with Luminance Audio, send him an email there I guess ...
Luminance Audio KST-150 - YouTube
i sent Steve an email, he may respond ....
Strange goings on. I get their main page now, but last time I got an advertising redirect when I clicked on the link on the audiogone profile.
The link for details to Virtual dynamics is dead. Last update on Luminance was 2 years ago.
Old 20th April 2012, 01:21 AM   #4516
diyAudio Member RIP
Originally Posted by abraxalito View Post
What am I missing?
I doubt much of anything
Old 20th April 2012, 01:29 AM   #4517
SoNic_real_one is offline SoNic_real_one  United States
What am I missing?
He measured the associated VOLTAGE dB with those power levels, not the actual POWER dB. Do you know of any THD measurement device that deals with POWER directly?
That makes for the 1mW/200W ratio -106dB, not -53dB...
Those "digital systems" don't have a class AB output stage that generates cross-over distortions at low levels:
Click the image to open in full size.Click the image to open in full size.
Old 20th April 2012, 01:43 AM   #4518
abraxalito's Avatar
Amp tests are done into a resistive load. Thus knowing the voltage we can infer the power.
Only if you were asleep during EE class. Power ratios are always 10log, voltage ratios 20log.
Old 20th April 2012, 01:45 AM   #4519
Like I already said (even you prefer to ignore it) probably he didn't measured power, he measured voltage. What tool would you use to measure directly the THD for POWER?
So when he said 1mW he measured the associated voltage on a specific load. 11.19mV on 8 ohm. Didn't measure the current too.
Sure, not correct in verbiage... but offers an explanation of his results.
Old 20th April 2012, 01:46 AM   #4520
diyAudio Member RIP
I doubt that it is class AB transitional distortion. Even Self (who defines his class B in a somewhat funny way) allows for some quiescent current at 0 volts out. And you don't need much. The objection (as you all know) to "rich" class AB is that the transconductance of the (typically) emitter followers transition to what is typically a lower value as the one device turns off completely at a certain signal voltage. No, I'm pretty sure John Halcro Candy had this under control, whether you like how his amps sound or not.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
