The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 30th December 2011, 10:46 PM   #391
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by SY View Post
Zero interest in that. There's plenty of guys out there (John included) who design excellent SS amps. Excellent tube amps are quite a bit rarer.
Excellent by "standard measurements", or excellent by clearness of sound? Let's go back to the topic.
The Devil is not so terrible as his math model is!
Old 30th December 2011, 10:47 PM   #392
john curl is offline john curl  United States
john curl's Avatar
I can't, but Richard Heyser mentioned it in one of his earlier papers. Need a cite?
"Condemnation without Examination is Prejudice"
Old 30th December 2011, 10:48 PM   #393
Wavebourn's Avatar
Real delay? That's an engineering term that I'm unfamiliar with. Could you define it?
Carriers of charges have inertia.
Old 30th December 2011, 10:56 PM   #394
jcx is online now jcx  United States
a ill formed question - 10 Hz corner frequency is only part of the equation - gain, how much is to be used to meet Av requirement, what’s "left over" as loop gain?
today common SS audio amp numbers are near 1 MHz loop gain intercept for ~160 ns delay - where single pole compensation, conservative phase margin good separation from higher order poles (mostly output stage) is employed
audio frequency "amp delay" can be harder to pin down with high gain circuits using 2 pole compensation - formally the output can just keep accelerating with constant input error signal within the linear 2-pole gain region
"newer" decades old parts like Mosfet, Ring Emitter output Q are probably limited by common "audio" layout practice, and the package parasitics before the "ultimate" limits of ft, transit time terms of the die themselves are a hard limit
if any competent engineer understanding the issues really thought "amp delay" was a problem then why aren’t they using IXYS Linear Mosfets in RF power packaging? http://www.ixysrf.com/pdf/diodes/app...elvin_lead.pdf
Old 30th December 2011, 10:58 PM   #395
wahab is offline wahab  Algeria
Propagation delay? Nanoseconds. Group delay is perhaps what you mean?
As already pointed , propagation delay in Bjts is extremely short ,
less than 10pS is a typical value and is indicative of the intrinsical
speed of the bipolar devices if they werent "infected" by parasistic
caps and resistors that are an inherent byproduct of the device geometry
and principle.
As for what is commonly understood as delay propagation,
it is the time it take for a device output to reach 90% of its
definitive value , wich is not a propagation delay but rather
a bad interpretation of the device slew rate.
Old 30th December 2011, 10:59 PM   #396
john curl's Avatar
The chicken before the egg. Before you can LOWER the delay, you have to use FEEDBACK to FORCE the input stage to compensate. IF the input stage is NOT perfect, then it will distort, and interesting things will happen. That IS the difference between open loop and closed loop delay.
Old 30th December 2011, 11:01 PM   #397
john curl's Avatar
Black Box with up to 10Hz, BEFORE rolling off at 6dB/octave. NO transistors, fets, tubes.
Old 30th December 2011, 11:10 PM   #398
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by Pano View Post
Don't be so hard on 1968 engineering. We went to the moon in '68, you know.
But of course didn't land there until '69.
se
The Audio Guild
Old 30th December 2011, 11:16 PM   #399
DF96 is offline DF96  England
There is a difference between the 'delay' added by a single-pole low pass filter, and the real delay added by a transmission line or other propagation mechanism. You can undo the first by inserting a complementary filter. You can't undo the second without violating causality, as you would require output to occur before input. Don't get the two confused.
Old 30th December 2011, 11:20 PM   #400
john curl's Avatar
We went around the Moon, perhaps, in '68?
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
Copyright ©1999-2017 diyAudio
