The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 25th March 2012, 05:08 PM   #3961
bcarso is offline bcarso  United States
diyAudio Member RIP
This wiki is o.k., although I dissent that Nelson really invented the concept, as such feedback goes way back (a tube amp with feedback to the input device cathode for example) --- and I believe that Comlinear lost some battles after that patent issued.
Current-feedback operational amplifier - Wikipedia, the free encyclopedia
Good for high slew rate, usually not so good for d.c. properties and distortion. Would represent a huge sea change in the context of the Hafler at this point.
Does anyone know of a high-end power amp that uses this approach? I vaguely recall some such but forget who it was, maybe dating back to the '80's when fast slewing was all the rage. On a bog-standard level the NAD3020 power amp section uses current feedback, and an ancient IC from STMicro, the TDA2007A, tried to have a current-feedback front end and additional voltage gain following, and was the devil to stabilize.
Old 25th March 2012, 05:16 PM   #3962
tvrgeek is offline tvrgeek  United States
Originally Posted by dvv View Post
That's what I'd do. Sharing of resources somehow always brings its own baggage, better not play with it, especially since the added complication and cost is truly negligible.
Simple enough. I had it drawn that way originally, but something keeps bugging me. There was an explanation somewhere why one actually did want to share, but I can't find it anywhere. Whatever it was, it is probably in the weeds anyway.
Old 25th March 2012, 05:45 PM   #3963
Not really topology, but doing the transient response, it is clear I need to up the feedback coupling cap to 220u, replace most of the resistors with 1%, and add diodes with larger caps on the rails for the VAS and IPS, with a rail to rail bleeder. Electro on the input will be replaced by a large poly. Obvious stuff.
If one built the amp as a current source rather than a voltage source, a-la Quad, than would one not want current feedback? I thought that argument kind of went flat not because it was not a good idea, but because most speakers are designed assuming a voltage source.
Old 25th March 2012, 06:00 PM   #3964
dvv is offline dvv  Serbia
Frankly, for the life of me, I can't think of any more but two reasons:
1. Less components, less real estate on the PC borad required, and
2. Less components, smaller price for materials and workmanship.
We often laugh at the price savings, and point out that at the volumes factories do their buying, a resistor, zener diode and capacitor probably don't cost them more $0.05 to buy - if that.
What we forget is that this saving is multiplied by the number of units produced. Say 50,000 - that works out at (50,000 * 0.05) $ 2,500.
Now, what do you think, off hand, what would a company rather do, lay down the money for extra parts which no-one can even see, or "invest" that money in advertising?
We here are in many ways the antipods of the industry. Just look at Thorsten and myself, here we are, using as many transistors as we feel like, in pursuit of what we hope will turn out be some cools sounds, but we are being damn wasteful from an industrial point of view. We do it because we are working for ourselves here, giving no thought to series production, and having no bean counter peering over our back.
In the actual industry, such things are reserved for only the most exalted of brands, whose price stickers NEVER ever have less than four figures and more often than not, five figures.
So, as I understand it, you are doing this strictly for yourself - indulge yourself then, if you have it, flaunt it, do it RIGHT or don't bother.
Old 25th March 2012, 06:04 PM   #3965
Emitter or collector to rail on outputs?
I noticed across various schematics, some put the PNP to the positive rail, most the NPN. Swap e for c of course. Is there reasoning behind this?
Old 25th March 2012, 06:06 PM   #3966
As I see it, current feedback, like any approach, has its ups and downs.
Up is the fact that it is more or less independent of voltage swing, works equally well with 1V and 20V output. Thus, your full bandwidth is preserved at all times.
Down is the fact that it is not easy to temper its DC aspects, needs more care and possibly a few more parts.
Voltage feedback is about the same, but in opposineg direction. Relatively easy to adjust a circuit's DC parameters, but dependant on voltage swing.
Don't worry about it. If you do, you will soon be asking yourself what the hell are you doing, modifying an amp well into radical waters, it would have been easier to build another one from scratch.
Old 25th March 2012, 06:09 PM   #3967
diyAudio Member RIP
Be careful not to confuse "current feedback" with "current source" or "current dumping" a la Quad.
Old 25th March 2012, 06:16 PM   #3968
Frankly, for the life of me, I can't think of any more but two reasons: ......
Having been through the Troy Institute for Maneuverability, and my first career as a manufacturing quality engineer, I don't forget the fractions of a cent. ( One could have a field day on cost of manufacturing of any amp I have seen. Little screws, bolts and nuts, too many assemblies) For the hobby side, I just think if it will be hard to bugger the board. There was some subtle technical reason. I will post it if I ever find it. Could have been somewhere in 20 years of AA.
I have another philosophy that has served me well. Fix the first 95% of you biggest problem and move on. Eventually, that last 5% will be your biggest problem. If it needs fixing, do so then. Why leave a problem? Well, if one gets carried away with tiny details, they may never get to the next really big problem. I see it all the time.
Old 25th March 2012, 06:16 PM   #3969
Not confused, totally ignorant.
Old 25th March 2012, 06:41 PM   #3970
a.wayne is offline a.wayne  United States
Sin Bin
Accuphase did ......!
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
