The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 17th March 2012, 10:45 PM   #3661
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by john curl View Post
Good approach, Wavebourn.
I would be surprised if it was not patented yet,
The Devil is not so terrible as his math model is!
Old 17th March 2012, 11:07 PM   #3662
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by dvv View Post
Which is exactly what Dan d'Agostino did and used them for, a very complex arrangment.
For audio, I usually swear by BF 720/721 - a transistor with uncommonly low distortion and actual, effective Ft. But I find that two parallelled MPSA 42/92 devices actually beat him all around, albeit by just a little. Also, their price is so ridiulously low that you can easily afford a large population from which to select them easily. In a handy, TO-92 package.
Maybe you need a good phono pre -amp ...
Mark Levinson JC2 preamp with phono (collectable) | eBay
Supposedly good .... !!!
Old 18th March 2012, 12:35 AM   #3663
tvrgeek is offline tvrgeek  United States
First conclusion: two 1N4148's do a far better job of being a voltage reference to the single transistor ccs than a red or green, all else the same ( emitter resistor adjusted for the same current.) What effects the high frequency response is the transistor. I wish I had models of more parts, like the 2SC1085. BC5550 does pretty well over the 2N5551. Te other curious thing is that the current with LED's does nasty glitching when the diff pair turns off.
Putting in a big cap, (220u big enough?) did not have effects in the simulator. Reality may well be a different story. I see that done on the "mx50" boards.
Now to play with zeners and maybe fancy new fast soft recovery diodes if I can find a model.
Old 18th March 2012, 12:55 AM   #3664
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by scott wurcer View Post
Wadax looks like an exercise in over-the-topness.
My sentiments too - the reviewer seemed to mention the 6.4Gbit/s bandwidth between their FPGA and the external memory somewhat in hushed tones as if spraying bits around the PCB incredibly quickly indicated superior engineering skills
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 18th March 2012, 01:10 AM   #3665
SoNic_real_one is offline SoNic_real_one  United States
Of course. Dynamic resistance of the LED is 4-5 ohms... What cap you need for that?
You know what part of specs did make me laugh? This one:
"USB lock range(KHz): No driver is needed. 48 KHz, 16-24 bits"
Oh... really??? Awesome, only if TI would get a hold of THAT marvel...
Old 18th March 2012, 01:55 AM   #3666
Hard to beat the original configuration. Tried cascode and feedback, tried zenier, tried cap. Small differences, give and take. Three conclusions: Pair of diodes beats an LED, transistor matters a lot more, and fancy configuration does not buy much.
I bet everyone knew that.
Old 18th March 2012, 03:08 AM   #3667
Wavebourn's Avatar
See my signature.
Old 18th March 2012, 03:26 AM   #3668
On Hiatus
SY's Avatar
I didn't. Experimentally, a red LED gives lower impedance and noise than a pair of diodes.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th March 2012, 04:23 AM   #3669
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Lots of great work, I don't think these folks get enough credit.
Yes, cutting records (especially all manual) is a serious art and one that is dying out. I wonder how many cutting engineers are left that can simultaneously read the score, gainride (to avoid overload or automatic compressors) and control the groove spacing at the same time AND get a perfect result almost every time!
Most folks simply do not know what went into making a record, from the master tape on a Revox C37, to cutting a lacquer master, via the various stages of electroplating to punching the centre hole and eventually pressing (and how many chances to screw it up royally).
Next to that making a CD Glass Master is trivial, though most of the time the CD pressing plants get that wrong too...
Ciao T
Old 18th March 2012, 04:28 AM   #3670
Originally Posted by Wavebourn View Post
The best way is to use digital delay once, recording resulting sidechain, then apply this sidechain to direct actual recording without any delays. Just 2-step procedure: adjust well then shoot once.
Funny thing, a good cutting engineer will do just like that, listen to the tape for the whole side, take notes of the time and what stands out, maybe listen again and then just sit down, gain control in one hand, groove spacing in the other, time display, score and notes taped up somewhere and cut.
For D2D cuts replace "listen to the tape" with "attend rehearsals".
Ciao T
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
