The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 17th March 2012, 08:41 PM   #3651
john dozier is offline john dozier  United States
john dozier's Avatar
I wonder if the digital delay was actually in the audio chain? Perhaps it was fed audio to adjust the servo for moving the cutting head, with the acutal cutter head fed seperately. I am not an analogue mastering engineer but perhaps we have a few on the board who would know if this split audio path was the case. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 17th March 2012, 08:46 PM   #3652
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Not great on cause and effect, are we?
You must delay the audio fed to the cutterhead, so that actua audio (not delayed) can be analysed for level and frequency content and then the groove spacing can be adjusted automatically so that the groves ALREADY have more spacing when the signal at the cutterhead demands higher excursions...
Ciao T
Old 17th March 2012, 09:03 PM   #3653
Well Mr. Expert at all things, how about two tapes played with a small offset, one to the servo the other to the cutterhead? Regards
Old 17th March 2012, 09:05 PM   #3654
BTW your snide comment was not appreciated. Great with customers I would also surmise.
Old 17th March 2012, 09:10 PM   #3655
This is how it was done BDD (before digital delays), actually one tape but two heads. You needed a fair bit of tape between the two heads though (several seconds worth, which 15ips gets long quick). This is a fairly non-trivial affair and the works often jammed up (or so I was told).
The best solution is still a human who can read sheet music and follow along making manual adjustments. Stan Ricker still cut's in "fully manual" mode, or so I am told.
The automated systems introduced by Neumann are a bit like the compressors everyone seems to insist upon putting on the final mix (instead of gain-riding the mix to domestically usable dynamics). It means fairly unskilled people can operate the system and get decent results, but there always is a price to pay...
Ciao T
Old 17th March 2012, 09:24 PM   #3656
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Ciao T
Lots of great work, I don't think these folks get enough credit.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 17th March 2012, 09:35 PM   #3657
john curl is offline john curl  United States
john curl's Avatar
The best way is to use two tape heads and a loop delay. This way there is NO digital interface, and a true delay. I designed the electronics for one for Mobile Fidelity, over 30 years ago.
"Condemnation without Examination is Prejudice"
Old 17th March 2012, 09:42 PM   #3658
tvrgeek is offline tvrgeek  United States
Will do. I had thought about that but my first attempts I was fooling myself by not looking at the right place. I also found a plug in to LTSpice that plots distortion across frequency. Easier than three of four separate plots. Still need to pick several levels.
I figure if I concentrate on such a "small" part while I get a better understanding of transistors, it will help much more further on. Spice has a lot of capabilities not obvious to an amateur and it just scratches the surface of reality. Lack of models and their completeness is one problem. I bet LT has a much better set that applies to on-chip parts with a lot more precision.
Got to do something waiting on my parts to complete a passive crossover, with BSC.
Oh, the comment about doo-doo. That is for those who build speakers out of perfect spreadsheet and web "design your crossover here" sites. Many do and and find out that is not all there is to it. For instance, the wider a baffle, the less deep I tend to make the BSC, not just the frequency. The pair I am doing right now is only 6 inches wide, and it took a lot of tries to get it happy. This particular design had a fixed aesthetic requirement so I could not play with the width and crossover points to achieve the same thing without the extra parts.
I am sure we agree, a studio monitor has a different job to do than my main listening speakers. The environment is different, solution will be different.
Old 17th March 2012, 10:13 PM   #3659
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
The best way is to use digital delay once, recording resulting sidechain, then apply this sidechain to direct actual recording without any delays. Just 2-step procedure: adjust well then shoot once.
The Devil is not so terrible as his math model is!
Old 17th March 2012, 10:16 PM   #3660
john curl's Avatar
Good approach, Wavebourn.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
