The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 14th March 2012, 03:44 AM   #3401
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by a.wayne View Post
OK some graphs looking at amplifiers, ones that knee buckles below 8 ohms and the ones that don't ...
Electrocompaniet, Goldmund, Plinus Class-a mode...
Alas, I do not see a SINGLE Amplifier in this quartett which precisely doubles it's output power from 8R to 4R for 0.1% THD.
So based on your evidence so far there is no Amp that "doubles down" under the conditions under which the Citation XX is specified.
Basically another case where the vendor with the honest specs gets beaten up over them while the BullS...t merchants are lauded as paragons of performance due to their less transparent specs...
I guess if HK had rated it at 250W8R/500W4R @ <0.5% THD (which they could likely have done) all would be well...
Ciao T
Old 14th March 2012, 03:46 AM   #3402
Originally Posted by bcarso View Post
When Harvey Rubens and I sat in the audience at a local AES talk about grounding issues with pro equipment, the speaker started his talk with "Hi. I'm George P. Maggilicuddy*, and I have a Pin 1 Problem". Harvey and I spontaneously erupted:
HI GEORGE!!!
Not that many people in the audience found this amusing, whether because they were recovering alcoholics or just uninformed or possessed of a minimal sense of humor, we never knew.
George may have been Bill (Withlock).
Given that it's the AES (and who it's leading lights are) I though proof of a double humorectomy was required before they let you in? How did you two sneak in...
Ciao T
Old 14th March 2012, 03:53 AM   #3403
a.wayne is offline a.wayne  United States
Sin Bin
Yes, true , then there is 2 ohm ....
Look at the graphs again T, all 3 tell a different tale, the goldmund and the electro really fall apart after 8 ohms , unlike the plinus and I'm not surprised I found the Plinus the best sounding ...
anyway put a bid in on the XX...........
Old 14th March 2012, 03:56 AM   #3404
Originally Posted by tvrgeek View Post
I am totally blank on what the H parameter charts are trying to tell me. When I see the Cob-Vcb chart, this is showing me the Early effect? What do I do with this?
All of this shows you how a devices parasitics change if voltage cross or current through the device change.
They allow you to derive the various parasitic resistance (early effect induced limited collector impedance, Beta changes, Changes of the internal emitter and base impedance as well as the parasitic capacitances), so they allow to tell you what goes wrong and where if you change voltages and/or currents (which you will as a transistor that works only static is not useful in an amplifier)...
Of course you can just blissfully ignore all the non-linear parasitics and throw a ton of looped feedback around the Amp instead...
Side note, The On-Semi datasheet for the 2N5401 is identical to the Motorola, right down to the defects in font.
That could be related to the fact that Motorola Semiconductors was spun off and is now called "On-Semi", just as Philips Semiconductors is now NXP and Hitatchi Semiconductors is now Renesas...
Ciao T
Old 14th March 2012, 04:00 AM   #3405
Your comments make me think you need a lot of power.
In this case the Plinius looks like it has the most distortion of all of them.
Maybe you just like distortion?
Ciao T
Old 14th March 2012, 04:03 AM   #3406
Sin Bin
So distortion measurements matters ...........
Old 14th March 2012, 04:04 AM   #3407
bcarso is offline bcarso  United States
diyAudio Member RIP
Ciao T
No, I know Bill. And this was no Bill
Old 14th March 2012, 04:07 AM   #3408
diyAudio Member RIP
Originally Posted by jcx View Post
no, say it aint so...
at least don't try to support the criticism with "conventional engineering", Bode Sensitivy analysis, build dedicated hardware like Cordell...
Langford-Smith 4th ed., Supplement section at the end, following the index. 1952 and prior cites. Obviously not as detailed as Otala, but the gist is there about feedback going "wrong".
Old 14th March 2012, 04:12 AM   #3409
No, this was "on line audio discussion standard reply # 1" when someone posts they preferred a Tube (High Distortion) Amp over a Solid State (Low Distortion) Amp...
Ciao T
Old 14th March 2012, 05:40 AM   #3410
godfrey is offline godfrey  South Africa
I still don't know why someone would put two 4148's in parallel with a red led...
I've seen that in another circuit, with a footnote explaining that it's optional to use either the two diodes or the LED. Maybe that's the idea here too.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
