Sound Quality Vs. Measurements Sound Quality Vs. Measurements - Page 283 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 26th February 2012, 08:35 PM   #2821
Pano is offline Pano  United States
Pano's Avatar
Seems to me there is too much focus on the top end of FR when talking about hearing loss.
Losses down lower seem more important to me. A loss at 6K or 3K can make quite a difference, even if your hearing does extend to 16Khz.
Upper mid-range losses can be caused by noise or ear infections. They will affect you hearing ability much more than the "I can't hear 18Khz any more" losses.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 26th February 2012, 08:51 PM   #2822
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Originally Posted by wahab View Post
As already said the graph doesnt say that it was the audibility
threshold of THD , in fact it was audible at levels way below 0.5%.
No such thing as the audibility threahold of THD. Like, no such threshold of healtahibility of average temperature of patients in a clinic. Like temperature of each patient means different things according to his/her diagnosis, audibility of distortions depend on many factors, like loudness, order, dynamic behavior.
The Devil is not so terrible as his math model is!
Old 26th February 2012, 08:54 PM   #2823
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by john curl View Post
Bacarso, why do you need this info?
Oh, I have ambitions of doing some "high-end" things I guess, but as well it would be nice to be able to recommend parts to people and have some confidence that I'm giving out reliable information. I spent years designing the electronics for cheap powered speakers that shipped in the millions, and enjoyed providing the best quality that could be accomodated by the cost target. Been there, done that, but unfortunately behaved in my expenditures as if it would go on forever*. Now things, almost impossibly, have gotten not so much cheaper but a good deal poorer, as essentially no one seems to mind
The tide may turn in time. At least the nonsense that youth prefer MP3 over higher-resolution audio, put forth on the basis of very poorly-controlled experiments by some professor, has been debunked by Sean Olive in better tests. So I think there is some hope.
Brad
*so my ambitions are thwarted if they are to make a small fortune, since I don't have a large one to start with.
Old 26th February 2012, 08:59 PM   #2824
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by bcarso View Post
IIRC the parts inside Scott's AD797 are around 6 ohms?
Yes, due to a rule violating layout. They are way smaller than most equivalent parts. But remember now there are several parts with sub-nanoVolt noise due to the sub-micron geometries that are available.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 26th February 2012, 09:08 PM   #2825
diyAudio Member RIP
Yes it's remarkable what is going on. I remember when Barrie G. told me about experimental devices at AD with complex structures that, among other things, were showing beta's of order 100k. A curiosity, although it makes finite beta less of a nuisance for translinear designs I suppose.
And in switchmode we have the advent of GaN, more things to grey the hairs of what Bruce H. has left , with switching frequencies posited as in the offing of ~50MHz. I think the magnetics lag a bit, although I saw a little 20MHz power supply the other day.
Old 26th February 2012, 09:58 PM   #2826
Originally Posted by ThorstenL View Post
Strictly as measuring mike.
In my case I actually have a Behringer ECM8000 which is the whole thing build into a measurement mike case. So someone else did the job for me. Otherwise check the Linkwitz site.
EMU 1616m or EMU0404USB external sound cards, also provide phantom power.
Not use it at all?
The WM61 does not make a good recording microphone IMNSHO.
Ciao T
This is a cute circuit for a modified WM61 or equivalent. The distortion will be from the capsule only.
Old 26th February 2012, 10:09 PM   #2827
john dozier is offline john dozier  United States
john dozier's Avatar
For those who care about speaker distortion, Soundstage, in their speaker reviews, provides data from the NRC on speaker distortion and specify the SPL. It is interesting that some highly touted speakers have relatively high levels of distortion. The spectrum of the distortion is also interesting. I assume it is THD only. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 26th February 2012, 10:57 PM   #2828
diyAudio Member RIP
Is the capsule cold side referenced to ground? Is there a gate resistor, and if so to what is it referenced?
Old 26th February 2012, 10:58 PM   #2829
diyAudio Member RIP
When you say it is THD only, do you mean that they don't attempt to measure IM?
Old 26th February 2012, 11:16 PM   #2830
No the gate floats biased by leakage current, just as in the normal connection.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
