The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 25th February 2012, 04:26 PM   #2741
wahab is offline wahab  Algeria
Out of curiosity i made some listening tests and surprinsingly
when using a 1KHZ sine THD contents are clearly audibles at levels
higher than -60db , wich is 0.1%.
A screen of the THD distribution , quite tubish for a class AB
solid state...
Old 25th February 2012, 04:34 PM   #2742
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by wahab View Post
Out of curiosity i made some listening tests and surprinsingly when using a 1KHZ sine THD contents are clearly audibles at levels
At what SPL was the test made and what is HD level (per harmonic - not THD) of the transducers used at that level.
Ciao T
Old 25th February 2012, 04:35 PM   #2743
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
solid state...
Do you mean "tubish" on onset of full power?
Tubish does not mean that. Tubish mean that when you decrease power higher order harmonics disappear, and at 1/10 of power only 2'nd and 3'rd are visible, and even they go down when you further decrease power.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 25th February 2012, 04:42 PM   #2744
bcarso is offline bcarso  United States
diyAudio Member RIP
I was just reading the historic series of articles by Jung et al. and subsequent letters exchanges from TAA about slew-induced distortion. Quite fascinating from both a technical and sociological point of view. So far I haven't found anyone mentioning that the reason the two-close-spaced-tone IM distortion test is poorly correlated with other measures of slew limiting effects is that, if the slew rates are symmetrical, the distortion is odd-order --- and thus the IM products, for example for a cubic nonlinearity, are at 2f1 - f2 and 2f2 - f1, i.e. on either side of the two stimulus frequencies.
When the slew rates are asymmetrical, then you will indeed get some even order including the simple difference frequency f2 - f1. But if that's the only thing you are measuring, trying to diagnose slewing problems, you will understandably be getting some poor correlations with, among other things, high frequency THD.
But surely someone discusses this sooner or later --- I just haven't seen it yet in TAA. But I have plenty of reading left to do.
Old 25th February 2012, 05:09 PM   #2745
Ciao T
Level is 12V Pk on a 4.7R + (0.5R//8R) load , the speaker is the 8R load,
this allow to reduce the SPL level while preserving about 16 damping factor.
The speakers are studio monitors Quested H108 , wich in this case were
driven with 1.2V Pk , about 100mW.
Their efficency is 90.5 db/1W/1m.
On the screen , the fundamental is at -5.83dB , very close to the -6dB line ,
while the line graduations are spaced with 6dB , wich imply that H2 is 46dB below the fundamental.
The amp is close to clipping and as output level is reduced
high order harmonics decrease more than the fundamental
level variation.
Low order only THD is reached well before 1/10 of Pmax
despite the amp having meager NFB.
Old 25th February 2012, 05:20 PM   #2746
Wavebourn's Avatar
Yes. Also, when sidebands are of different highs that means phase intermodulation.
Signal generators and oscilloscope still are nice tools, if to know how to use them properly. Like, a flashlight is good tool when you can guess where you could drop that car keys on dark parking lot.
Old 25th February 2012, 05:24 PM   #2747
Wavebourn's Avatar
level variation.
So, on 1/10 of Pmax it is way below 0.1%, and low order.
I doubt it will be audible, even if on peaks it is as pictured.
Thorsten asked precisely right question, about level of loudness. Dynamics matters more than static numbers when they are so small.
Old 25th February 2012, 05:34 PM   #2748
Indeed , with a musical signal , even the screened high THD
would be inaudible given the huge amount of harmonics
produced by instruments.
I did the test at low SPL , agree though that perception
is different when reaching tympani compression....
Old 25th February 2012, 06:51 PM   #2749
Level is 12V Pk on a 4.7R + (0.5R//8R) load , the speaker is the 8R load, this allow to reduce the SPL level while preserving about 16 damping factor.
So the SPL is around 80dB at 1m and probably lower than that at listening distance. The human hearing becomes more sensitive at these fairly low levels.
Speaker HD would arguably be low.
So it is not 0.1% THD, but over 0.5%, a difference of more than 14dB compared to your claim.
Can 0.5% THD with harmonic structure like you show be heard on an 80dB SPL pure tone? Yes, very likely.
Now can 0.1% almost pure 2nd HD be heard at 108dB SPL with pure tones?
Ciao T
Old 25th February 2012, 08:17 PM   #2750
dvv is offline dvv  Serbia
Which slew rate?
Voltage, as V/uS?
Or current, as A/uS?
All too often, and very typical of particularly Japanese gear, while the voltage slew rate can even be outstanding, the current slew rate is something they know nothing about, and if even mentioned, you are expected to hara kiri at once.
Others, such as for example SAE, did quote it as 20 A/uS for their mammoth 500 WPC amp.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
