The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 7th February 2012, 07:36 PM   #1991
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by bcarso View Post
My favorite design managed to get a full-wave detector with complementary polarity outputs out of one transistor,
Cute. I usually can afford an 084 in the BOM if I need that though.
which in turn drove a four-transistor current-steering cell wrapped around a power amp which incorporated a two-pole underdamped highpass, whose low-frequency boost got attentuated preferentially when things began to compress.
Yuck. Fets are really not THAT expensive...
A little bit of mid-dip EQ compensated for the 2Pi-4Pi transition in the midrange, and overall it was a pretty decent pair of speakers to flank a monitor. One of the nicest parts was that the industrial design was, for once, something good for acoustical directivity, with smooth, rounded features that minimized diffraction.
At a guess, the **** Fader design from Just Brutally Loud?
I can listen to music through them without fretting, casually, although obviously with limited low-frequency extension and overall SPL. Anything but high-end though! The bill of materials cost was shockingly low.
Yes, it's amusing just how low one can go and still enjoy music casucally. My office has a Linksys "Wifi Radio" with some modest tuning# that streams music from my main Media Server or internet radio, I prefer to have it on, rather than off...
Ciao T
# to wit cheap bamboo chopsticks liberally applied to speaker surfaces and the 4" Driver spamped basket with 2-component epoxy, some Elna Silmic Cap's and around 0.03F in extra PSU capacitance for the Amp's (TDA2003), tweeter crossover cap changed from bipolar 'lytic to Film, most RCA and 3.5mm Jacks bypassed and hardwired, some Os-Cons in the digital section [which has a fairly high end AKM 24 Bit DAC actually] and an AD8066 instead of the original horrible Op-Amp as analog stage
Old 7th February 2012, 07:44 PM   #1992
john curl is offline john curl  United States
john curl's Avatar
Of course T, there are exceptions, AND I often forget that most people have low power mid-fi amps, and low efficiency speakers. I have done this combination (with some success) with an Electrocompaniet and a pair of WATT PUPPY's, and as well driving the same WATT 1 loudspeaker with a DYNA MK4 (40W on a good day). Here, I have to draw the line, and admit that these combinations or even worse ones, exist, AND clipping is possible, but I never found a need for limiters, even then, because the Electrocompaniet or the Dyna handled peaks very well, AS they are both low feedback designs.
I can certainly see how a 10W (on an exceptional day) solid state power amp built into a sound card, can clip, and clip badly!
"Condemnation without Examination is Prejudice"
Old 7th February 2012, 08:31 PM   #1993
bcarso is offline bcarso  United States
diyAudio Member RIP
The powered speaker (not a soundcard amp) was actually an "aftermarket" product sold in the Apple stores and otherwise online, branded JBL. The power amp was a very tricky-to-make-stable TDA2007A class AB amp, which has, I understand, now finally been discontinued.
The transducers were Clayton Williamson specials with remarkable x max for their size, and some pleated surround invention that enhanced linearity a bit (but there is still a boatload of IM distortion that will show up when pitched transients are mixed with significant low frequency energy --- but that's where the frequency-dependent compressor helps a lot).
The four-transistor cells, using unmatched 2SA1162GR PNPs (but usually from the same wafer) worked very well except for the approximation to a properly translinear Gilbert circuit, in that it lacked the predistorting diode-connected parts. So there's a little propagation of control voltages, but not reproduced with the limited LF extension to speak of. 1162s were about 1.2 cents then in high volume, an incredible bargain; not sure how much now. FETs are problematic for adjustment-free circuits owing to the huge spreads in production on pinchoff voltage etc., although one can use them as choppers. Many are the ways
But I really think the thing I like besides the circuit tricks (I look at the schematic and each time forget how it works for a while!) is the smooth curved baffle. Within the limitations of a single-transducer system, it has very acceptable dispersion.
Harman shipped about 800k of them the last time I checked, and made an obscene amount of money. If I had only been smart enough to work out a licensing deal They have also been remarkably reliable, although I don't know the exact numbers.
Old 7th February 2012, 08:40 PM   #1994
tvrgeek is offline tvrgeek  United States
I have had many amps with clipping indicators. Don't know if they worked as I can't remember ever seeing one on. Maybe that is why I still have decent hearing.
Old 7th February 2012, 08:51 PM   #1995
Originally Posted by DF96 View Post
Any decent economist would be quite good at maths. The weakness of economics is that when creating their equations they make false assumptions about how markets work etc. They then find a correct solution to the wrong equation. Physicists are now beginning to muscle in on economics, using either better assumptions or (shock!) the results of actual experiments or simulations of how people really interact. It turns out that economic systems can exhibit behaviour analogous to phase transitions. To some extent this explains the world crash, which most economists did not see coming.
You have a clear oxymoron in this statement. "Decent economist". If you put 12 economists in a room and ask them what happened yesterday, you will get at least 13 answers. Economics are nothing but some tools to describe one small aspect of sociology. BTW, my minor was econ.
Old 7th February 2012, 09:01 PM   #1996
dvv is offline dvv  Serbia
What you said is very near the truth. Macroeconomists in particular tend to regard the world and its markets as a set of equations, which is very foolish because you can't pack people into equations. Motives are often other than economic, politics play an ever larger part in the working of the whole world. Since politics are rather prone to sudden changes and swings, and disregard laws of economics all too often, their assumptions are very often based on questionable trends.
Another problem I've noticed is that virtually none of those macroeconomists has even one second of time spent in an actual, real world company. What to them appears to be statistically insignficant may actually lead to the ruin of companies who are unable to profitably implement what was envisaged by some smart *** in a mahogany office. But, that's also the key problem of politics the world around, I think.
Old 7th February 2012, 09:14 PM   #1997
Originally Posted by ThorstenL View Post
Hi John,
I guess I just ratchet up the Speaker Efficiency instead.
The highest efficieny speaker I have used long term was 104dB/1m/1W (not 2.83V, but 1W) the lowest ones often hover in the lower 90's...
Of course having a really quiet 150WPC or bigger Amp on a pair of near 100dB efficiency Urei's or similar main studio monitors is seriously silly grin inducing.
I occasionally clip my 35W Tube amp into my current 91dB/W/m speakers, but it's a tube amp with no global looped feedback so it can be overdriven quite hard before it goes from sounding "peak compressed" to "distorted", probably on the region of 6dB peaks above nominal power...
When the Amp goes from compression to obvious distortion I usually fear the neighbours in my Condo will pull my fuses.
Ciao T
I seem to have something not quite, but approaching that. My speakers are rated at 92 dB/2.83V/1m, and are often powered by a Karan Acoustics KA-i180 integrated amp, delivering nominally 180/250W into 8/4 Ohms.
On top of which my room is rather small, about 4.5x3.5 m (app. same in yards), so basically I never really needed much power. So, theoretically, I have 22 dBW in tap, which should give me a theoretical (92+22) 114 dB SPL, not counting the fact that there are two speakers at work, or the room reverberation, etc.
In practice, I have never managed to go past the 10 o'clock mark on the volume control because by then, my window panes start to boogey with the music, they get into it, man.
Old 7th February 2012, 09:25 PM   #1998
Thorsten, this world is no longer ruled by econonmics, it's ruled by out and out greed. Examples are so many, it's hard to pick any one out.
But think of this. We hear day in, day out, how USA has an incredible national debt, how Greece does as well, as do Spain, Portugal, Ireland, etc, etc, etc. Now, when you use "maths" to simply add up all those numbers, you have to ask yourself - if one country borrows, surely it borrows from another country which has a surplus it is willing to lend, right?
But, all those borrowings, when added up, total the world's three year planet Earth production. And since just about everybody owes, one needs to ask: where does all that money come from?
The answer is painfully obious - from national money printers. That "surplus" in effect does not exist.
Which means that you are out of economics and head on into politics; in economics, if you are serious about it, you deal with real resources, not imaginary. In the end, as the theory of accounting dictates, the balance sheet must equal zero, and in our case, it has long stopped being zero. The entire system has been hijacked into imaginary assets and as such, it can no longer be called economics.
A much more appropriate name would be a con.
Old 7th February 2012, 09:45 PM   #1999
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I've found this world 10 years ago, it is Recyclonomics.
If ROHS caring of recycling industry dictates what to use in manufacturing, it is Recyclonomics. Need for faster recycled goods dictate needs for investments that are borrowed from the future profit from sale of goods being recycled.
Edit: economists obviously keep out of equation the fact that resources when recycled loose their value, and Mother Earth can't replenish them with the speed they anticipate.
The Devil is not so terrible as his math model is!
Old 7th February 2012, 10:27 PM   #2000
wahab is offline wahab  Algeria
No , it s lended from private banks who are allowed to lend 20$
for each 1$ they have as deposit.
As such the private banks , who had been given the right to create
money out of thin air , did in fact lend even the money that they
didnt detain , that is , your money , my money , everybody s money.
As said , it comes frome nowhere , it s pure book entries , that is
0 and 1 on hard disks...
The amount of derivative contract in notionnal value is currently
about 900 000 bn$ , fifteen times the annual world production.
That s it , what is called the financial world create false money
and use it to buy all existing ressources.
The only scientific trait is that it s the application
of the law of least effort , that is , optimisation
of financial preadation...
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
