The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 5th February 2012, 01:01 PM   #1871
tvrgeek is offline tvrgeek  United States
dvv, gootee,
I notice in one of the application guides for l-MOSFTES they are really specific to get both the gate resistor and tons of bypass right at they devices. I know in my digital logic days how critical it was to keep the bypass caps right at the legs. Some "bright" engineer wanted to save money and instead of a .001 at every chip, put a .01 at the end of the row. It was not cheap to lay out new boards ( 6 layer) and do it all over again. A class I tool from AMP in interconnection pretty much said you should put a bypass cap on anything that uses power and turns on or off. This is of source where the art of board layout gets hard.
Changing to the HEXFRED rectifier and new main caps, the ripple on the rails is about 25% less. About 12mV on the input side, 40 on the output side. No surprise. The shape of the little "burp" where the diode turns off looks a bit more rounded. I will try to look at the residual distortion today. I did keep a "before" graph.
Old 5th February 2012, 02:58 PM   #1872
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by TheShaman View Post
I'm sure Jan will be happy to publish an article with the "correct" math. As I said before, it's easy to talk the talk but harder to walk the walk.
Why should I care?
If Bruno likes he can correct what he has written.
BTW, the effects are quite easily measured.
Then again one might argue that if the HiEnd industry could afford bright scientist to do some solid R(esearch) before they actually get down to D(evelopment), we would see some real progress and not the recycling of 1970's technology.
Sorry, I don't do '70's tech. It's either 1910's tech (Vacuum Tubes) or very recent.
Regarding Bruno's preference, he's stated in numerous occasions that a properly built statement Class A amp will be untouchable by any Class D design.
And? Has that anything to do with the topic?
But his definition of "proper" is not what we're used to seeing - esp. in the "less is more", "the 1st watt is the best", "feedback is bad" DIY world we live in.
He is welcome to his definition. I know several of his designs quite intimately.
But let's recap.
For starters, up to now, not one Technocrat has provided proof positive that low THD is a valid design goal, in fact much evidence exists that show that comparably high distortion levels (of a certain spectrum) are in fact inaudible.
Secondly, Bruno's article elected to ignore significant factors that would have changed his analysis, meaning his analysis needs improvement. In fact the only value of the article I can see was that it attracted a range of criticism which ultimately gave a new insight (from BP), namely: "Negative feedback does not attenuate the harmonics of the open-loop nonlinearity, but of its inverse."
This should make it even more clear why disregarding distortion of distortion is a crucial fallacy.
Anyway, whoever may wish to believe BP's article is the ultimo ratio on the whole feedback subject is welcome to their beliefs.
Ciao T
Old 5th February 2012, 03:37 PM   #1873
CopperTop is offline CopperTop  United Kingdom
Presumably high THD = high IMD, and conversely low THD = low IMD..? It would take a very sophisticated (digital) box of tricks to provide harmonic distortion without intermodulation distortion. Are you therefore saying that high levels of some types of IMD are also inaudible? With what source material?
Old 5th February 2012, 03:41 PM   #1874
Power supply improvement for DH 120. Put in the Hexfred rectifier, new main caps of 2200uF instead of the 6600 and they have half the esr.
Referenced to 1.68v as 0DdB. 60Hz improvement of 6 dB, 120 Hz of 19 dB, 180 Hz of 13 dB. Drop in higher order in the 2 to 3 dB per harmonic. No residuals above 1K as was the original case. Noise floor below 60 Hz dropped by 5dB to -113.
So I am back to where I started from, confirming some basic power supply improvement.
I am happy it is an amplifier again. Hard to probe and work on the way it is stuffed in the case. I think I had best continue learning Spice and breadboard some of it rather than apply my bad vision and fat fingers to tight quarters.
Old 5th February 2012, 03:42 PM   #1875
Yes.
Yes.
Music, pure tones. SPL plays a role here. More HD/IMD is tolerated at higher levels.
Ciao T
Old 5th February 2012, 03:51 PM   #1876
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
[snip]Ciao T
He has shown that your arguments are in error, many pages back. Funny how memory deteriorates when you get older...
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 5th February 2012, 03:52 PM   #1877
Could use a DC servo. Watching how the offset moves around from 4 to 25 mv depending on input. It is slow enough to suggest thermal effects.
Old 5th February 2012, 03:56 PM   #1878
Jan,
My memory must be indeed bad. I do NOT remember him providing numbers for "distortion of distortion" that allowed simple dismissal as unimportant, but please, what is the post where he does so?
Ciao T
Old 5th February 2012, 04:09 PM   #1879
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Wavebourn View Post
You never heard class D tape recording amp, did you?
You know i can't recall ever hearing one ....
Originally Posted by dvv View Post
I'm not so sure about that.
I've come across some really wild loads; retracing Otala's steps, I tried AR3a Improved, Yamaha NS-1000,etc, all the way to the notorious "amp killer", the Apogees.
The thing is that amps, the behavior of which with the 1uF cap proved better than with others, ALSO drove the said speakers more to much more convincingly than the others did.
So, while I do not claim that an amp which "fails" that oversimplified test cannot sound good, I am claiming that an amp which does pass that test has a better chance of sounding good with real world speakers than the one which doesn't pass the test.
+10 , those that pass will go on to bigger and better things .....
Old 5th February 2012, 05:11 PM   #1880
DF96 is offline DF96  England
Recognising that with high feedback ratios we are actually seeing the inverse of the amp response is surely equivalent to 'distortion of distortion'? That is where the algebra leads us.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
Copyright ©1999-2017 diyAudio
