The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 26th December 2011, 10:58 AM   #161
CopperTop is offline CopperTop  United Kingdom
Is feedback via microphony a factor in the sound of tube amps? Presumably an amp driving a dummy load doesn't experience it, but when driving speakers in the same vicinity it must have quite an effect, no?
Old 26th December 2011, 11:22 AM   #162
With all this talk of the imperfections of what appears to be a simple device - an amplifier - and the apparent problems of feedback, I'm surprised that no one mentions the idea of real feedforward error correction i.e. learning exactly what a low-ish feedback amplifier is going to do, and pre-distorting the input to compensate. I presume that this would only be applicable to a specific load, and ambient temperature etc. but would get you closer to perfection without the evil feedback. If you were prepared to countenance the devil's own digital, you might do it with, effectively, a neural network that is trained to massage the signal non-linearly in many dimensions rather than just a simple FIR filter. I rather like the idea of connecting a neural network to wheezing steam-powered vacuum tubes.
Old 26th December 2011, 11:30 AM   #163
On Hiatus
SY's Avatar
In some, yes, others, no. IMO (no proof), this is likely a major factor in the "sound" of DHT amps.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th December 2011, 11:50 AM   #164
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I'm afraid I'm being left with the impression that this all seems not that much different than forecasting the extended weather for any particular square kilometer of the Earth's surface.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 26th December 2011, 11:52 AM   #165
suntechnik is offline suntechnik  Russian Federation
It might be due to microphonic tubes or because of difference of an assumed behavior of a dummy load and real speakers.
For example I am seriously skeptical about electrostatic panels or Maggies powered by a Graaf that would roll off at 20KHz. As well I am seriously skeptical about audiophile that will use Graaf gear with inferior speakers limited up to 20KHz.
However no doubt that perfect 300B SET sound could be easily killed by a wrong loweff solid state oriented speakers especially in bass octaves. In contra hieff Fostex with oscillated ssamp would be an insane headache and in most cases with hi-fi consumer ssamps Fostex or Klipsch is a headache.
Old 26th December 2011, 11:56 AM   #166
@SY
What sort of levels of microphony are we talking about? People round here can readily discern distortions and noise at 100dB below the signal (so they say) and from my own experience of shouting at a 'valve' (as we call them in the UK) and recording the result in the past, microphony could be much higher than that. Presumably it's not always harmonic, and not linear..?
Old 26th December 2011, 12:08 PM   #167
On Hiatus
SY's Avatar
People round here can readily discern distortions and noise at 100dB below the signal (so they say)...
Your parenthetical is spot on.
If tapping on various spots on my amplifier produces no discernible sound from the speakers, I cease to worry about this as an error source. The microphonics from DHTs that I've tapped peak right in the brightness range, thus my speculation.
Old 26th December 2011, 01:17 PM   #168
Isn't it a strange coincidence that the point beyond which amplifiers start to behave unacceptably, apparently, is at the upper limit of human hearing? The same electronic components that are used for processing signals in the many megaherz or gigaherz ranges (i.e. nothing to do with audio) can only just be configured to reproduce a complex waveform whose components are all within a bandwidth of 20kHz, or so it seems. It's a good job that the physics of air, and the laws of biology mean that our ears evolved the way they did.
Or is it the case that even if our ears ran out at 10Hz, people would still manage to make a living telling us that our amplifiers are rubbish, and that they can hear huge differences between valves and transistors, and that circuits without feedback are so much better than those with?
Old 26th December 2011, 03:36 PM   #169
tvrgeek is offline tvrgeek  United States
Originally Posted by SY View Post
That has zero to do with being a compressor.
I would say some as the various methods effect where on the curve the tube runs and all the interrelated effects that argument or cancel each other. Hint: "curve" I have only built a couple of tube amps on a junk Chinese 6P1 chassis and my only textbook is the one from Jones, so I may be missing something.
Going back to find hints as why one may prefer one technology or another, what do you think about compression fooling one to think there is more detail? Just like how many JBL speakers jumped off the shelf in the old L100 days because of their pronounced mids. A/B test, WOW factor et al.
To earlier comment on price. Granted, at any price point, good design is still good design. Unfortunately, pretty quick the designer has to decide to spend real money. Bigger transformers, regulators, replacing resistors with ccs'a and so on. Good mechanical build gets expensive too. I am sure those out there who design commercial products can attest how hard it is to bring a concept in and still reach a viable market. That's the other 90% of engineering.
Once these things come together they exceed my range of excuses. All of this is luxury. None of us need any of this stuff. I am perusing these thoughts as a hobby, to learn, to understand. Besides, I sold my TVR so I have to have some trouble to get into.
Thanks John on reminding me how old some of those amps are. It would be a far better shake to get hold of a much newer one. One from this century.
Old 26th December 2011, 03:45 PM   #170
john curl is offline john curl  United States
john curl's Avatar
Coppertop, the REAL answer is to listen for yourself, and to trust your own responses to different amplifier designs. It is true that we audio designers do NOT completely understand what is most important in amplifier design, and I personally have striven to understand it for more than 40 years.
My personal philosophy is to try to cover EVERYTHING that I know is potentially an 'error' in an amplifier's design. So, I will start with the most linear circuit topology that I can think of. Then, I will run it as close to Class A as the heatsinks available will allow. Then, I will make sure that the circuit is fast, at least 100V/us, often faster, and stable with virtually any capacitive load.
Then, (in short form) I will make sure that the amp has lots of peak drive current capability, 30A min, 60A typical.
Finally, I test for the worst case crossover point in the transfer function and monitor the 7th harmonic distortion generated. This is at the transition between Class A and Class AB (about 25W in the JC-1).
Am I completely successful? No, but I do pretty good. There are people of my acquaintance who have owned and sold their JC-1's for another amp. One of the other amps is the AYRE. It is ALWAYS a wake-up call when this happens.
Now what advantages does Charles Hansen of Ayre, have over my Parasound designs?
First, he has COMPLETE control over his design. I am limited to circuit design, getting a proper circuit layout and most of the obvious active and passive parts.
I have little control over internal connectors, housekeeping circuits, protection, RFI proofing the power supply, being stuck with a huge toroid transformer, rather than a super-quality EI or R core transformer. I'm not complaining exactly, I get to control the bulk of the design, but IF I personally made the amp, myself, it would cost at least 3 times as much and sound only a little bit better, on some occasions. In this case, the associated equipment and audio sources would dominate any decision as to an audio difference. But heck, I could pick the exact brand of solder, even, just like I did with the CTC Blowtorch, that just about everybody likes. '-)
"Condemnation without Examination is Prejudice"
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
