The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 25th December 2011, 08:18 PM   #121
Conrad Hoffman is offline Conrad Hoffman  United States
On the 627 thing, I used to use these for scanning tunneling microscopy; there was not much better out there for working with signals on the edge of existence. IMO, the input current and general behavior of the input stage is extraordinarily good.
That said, I have little opinion on their sound qualities one way or another for audio use, but my feeling is that people are paying a huge premium for characteristics that probably don't matter much for audio applications. It's another case of, "It's expensive and hard to get, so it must be better."
I still prefer the newer National (TI) parts because they're inexpensive, have lower distortion and are indistinguishable if the circuit is properly designed. If you're hearing differences between high performance opamps that don't show up with spectral analysis, differential or other methods, something is wrong.
I may be barking up the wrong tree, but at least I'm barking!
Old 25th December 2011, 09:27 PM   #122
On Hiatus
SY's Avatar
Originally Posted by a.wayne View Post
Do tubes have more "effect's" than SS ..............?
Depends on the design. You can design either to be colored or either to be neutral.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th December 2011, 09:48 PM   #123
a.wayne is offline a.wayne  United States
Sin Bin
Well considering that most tube amplifiers are power rated @1% thd and most SS at .01% from a pure technical position (taste's aside) it would appear tubes have more inherent distortion , more slewing, low damping and limited bandwidth (especially in the bass).
With all due respect, i find it interesting the cognitive dissonace of those building and designing tubes, where it does appear a lot of sound vs measurements is being practiced, especially when one consider their technical stance in other areas and the importance placed on such measurement for deciding good , better , best...
Just my Observance ....
Old 25th December 2011, 10:29 PM   #124
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Absolutely not. The right answer is: tube amps even without heroic efforts to minimize THD and maximize DF can sound better.
However, high output resistance of tubes and low output resistance of dynamic speakers require output transformers that are tricky beasts. You can get wider bandwidth, better DF, lower THD, using much more expensive output transformers, but it does not worth it, since sound quality improvement from such heroic efforts is questionable.
I myself had such belief when was young, that absence of output transformers, availability of complementary devices, guarantees better results with transistor amps. No matter how good my complementary totally symmetric SS amps were measured, anyway that stubborn professional tube beast Tesla Mono-130 sounded better, cleaner, more transparent. Much later, when I returned back to audio design, and made tube amp that measures like best transistor amps in terms of THD, bandwidth, and DF, I finally realized how wrong I was thinking that tubes were worse devices than transistors.
The Devil is not so terrible as his math model is!
Old 25th December 2011, 10:40 PM   #125
Is "it" the tubes or the transformers that provide the magic? I'm thinking of the McIntosh solid state amps that still use transformers.
Old 25th December 2011, 10:53 PM   #126
Wavebourn's Avatar
Honestly, I don't hear any magic in McIntosh solid state amps. I've repaired recently one, it has just optimal design, unlike other amps that were made in order to get some specific measurements as best as possible without sound quality in mind.
Old 25th December 2011, 11:13 PM   #127
tvrgeek is offline tvrgeek  United States
I wonder, with the basic tendency of a tube to act like a compressor more than a transistor does, maybe one raises the average level a little and the perception is more detail? Dependent on where the tube is biased along the load line of course. I don't recall much discussion about gain being non linear and its effect on subjective results. I remember back when our systems were full of peak unlimiters and various other boxes which all generated "impact" but in the long run were dismissed as not as musical. An LP at 65 dB range on a good day sure does not have the theoretical level of detail a CD does, but if you don't mind the other aspects, can be more, dare I use such a subjective term, involving? This should be easy to test. I think one of my DSP packages has a compressor.
Grasping at another straw, we typically measure amp distortion with a resistive load. Should we be measuring the difference to a captured sound from a reference speaker system? Are some of the subjective differences only measurable with the complex loads, or as Linkawitz describes, totally evil passive crossovers? Some far more evil than others. I might expect the full range driver camp to chime in here as that is the basis for their pursuits.
I quit playing with tubes after a few rounds of adding solid state rectification, bias control, and phase splitter. Each both measurable and sonicaly better. The end game would have to have been replacing the outputs with transistors. End of my tube experiments.
Old 25th December 2011, 11:22 PM   #128
On Hiatus
SY's Avatar
Originally Posted by tvrgeek View Post
I wonder, with the basic tendency of a tube to act like a compressor more than a transistor does...
Really?
Old 25th December 2011, 11:39 PM   #129
Er, yea. It is not linear either. Enter where the discussion splits to ccs vs cvs vs a resistor on the cathode.
Old 25th December 2011, 11:48 PM   #130
wahab is offline wahab  Algeria
This , is unrealisticaly exagerated and at odd with all known
measurements/comparisons of best tube amps vs common SS amps,
let alone these latters best ones , unless you re talking about the
early transistorized amps , of course...
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 09:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 10:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 04:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 04:02 PM
Copyright ©1999-2017 diyAudio
