The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 21st January 2012, 02:42 AM   #1201
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
No, believe I can't hear -80 dB 2'nd harmonic of my Pyramid amps on a half of output power (40W), especially when it goes all way down under noise floor when power goes down.
Your optical couplers are fantastic, but THD and dynamic range are quite different things.
The Devil is not so terrible as his math model is!
Old 21st January 2012, 02:46 AM   #1202
vanderpol4 is offline vanderpol4  United States
Originally Posted by SY View Post
Really? I would have thought 80dB. Could you explain to a dummy how you got that number?
I assumed Power ( audible) vs voltage(signal)??
Percent to dB Conversion Calculator
bet you can't hear 80 dB down SFDR
Old 21st January 2012, 02:52 AM   #1203
Wavebourn's Avatar
THD measurement operates by voltages.
Old 21st January 2012, 02:55 AM   #1204
On Hiatus
SY's Avatar
That's the difference. Never occurred to me to use power. Thanks!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st January 2012, 03:11 AM   #1205
BFNY is offline BFNY  United States
Guys that live in the "other" world, Wireless and RF, tend to think in terms of power, not voltage. They always use 10 log ratio, not 20. But for audio voltage measurements, it should be 20 of course.
Old 21st January 2012, 03:34 AM   #1206
Default Life size model of the human cochlea with optical readout
Yes and which one matters????? which one can we actually discern?
Gan Zhou and I with Dana Anderson once wrote a paper "life size model of the human cochlea with optical readout" published in JASA. The physics of the cochlea were amazing; as you probably know up to 500 hz a WKB 1-D approximation modeled cochlear traveling wave response pretty well; the basilar membrane response is really quite broad. Above 500hza 3-D model is required and the traveling wave ( like a Tsunami ) membrane deflection is much more peaked in response. past ~ 3khz the the cochlear pressure response is very peaked and we found 15khz was about 5mm from the stapes, hence the 25khz or so discrimination threshold for lucky individuals.
Sadly we never ran two tone etc. through the lab cochlea but the 1khz and below basilar membrane response seems really broad for a highly discriminating response to say an in phase 500hz and 1khz two tone signal.
above 3-5khz and it would be pretty localized, so I would guess 2nd harmonic 1khz and below would be threshold limited on auditory response
Old 21st January 2012, 04:36 AM   #1207
Wavebourn's Avatar
I agree with you that 100 times difference in voltage levels mean 10 times difference in sound pressure. And my own understanding of audibility of errors goes from other direction than analysis of physical hearing apparatus: perception is more than physics, it is combination of sensory perception and mental image manipulations. And if it grew up during evolution to recognize sounds distorted by physical media, such distortions are perceived as information about sound sources and environment, while distortions added by electronics differs a lot, especially in dynamics.
Old 21st January 2012, 05:04 AM   #1208
Totally agree. For example a simple experiment, listen to your favorite music drummer, sax etc. and "close " one ear, I know for me the timbre, "air" , "realism" vastly changes for the worse; ( haven't tried it with headphones though), I have always suspected the "difference" in the sound of amplifiers at moderate volumes has something to do with our sensitivity to lateral phase & amplifier interchannel crosstalk with phase delay; hence the love of dual mono power supplies..
Old 21st January 2012, 05:20 AM   #1209
Wavebourn's Avatar
Or, go to Siberia during summer, seat on some nice meadow with flowers, look on the water in a lake... After half an hour try to explain how do you locate mosquitoes flying around your head and body, killing them without paying attention.
Old 21st January 2012, 09:00 AM   #1210
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
That leads to confusion too, SPL is dealt with like voltage (mV/PA for instance). If you want real confusion photodiodes are A/W.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
