The Lounge A place to talk about almost anything but politics and religion.
Sound Quality Vs. Measurements
Old 3rd February 2014, 03:15 AM   #11771
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
Well, a person could try a step-down ac power transformer into an FFT/spectrum analyzer to see what and how much is in the audio freq range and choose or design a filter for those unwanted freqs.
Most power transformers have a BW greater than audio frequency range.
Thx-RNMarsh
Old 3rd February 2014, 04:23 AM   #11772
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
That method would only show up normal mode (i.e. differential) noise. I've been talking common-mode noise - so has dvv I think.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 3rd February 2014, 08:05 AM   #11773
dvv is offline dvv  Serbia
Originally Posted by abraxalito View Post
What the man said. 'Nice clean earth' is a popular audio myth - the reality is grounds are just sewers for everyone's (including one's own) electrical rubbish. Common-mode filtering, its the only way to go.
When I see a supposedly 'high end' audio component with one of those filter 'blocks' with an IEC inlet and some internal caps and chokes, I'm chuckling to myself. It tells me they probably just stuck it in there without much thought. Those pre-packaged filters get their datasheet figures for mains noise suppression from testing labs where's there is a decent groundplane to make the measurement. Given a noisy earth (most people's setups) those figures go out the window pronto.
This is a truly grey area, Rick, those IEC sockets.
Technically, you can't bitch about them because they do work, but the problem is that they kick in after 99.9% of the garbage has already gone by. Typically, they kick in at 600...700 kHz, but according to my experience, some 95-96% of the unwanted junk is done by around 80 kHz, which includes harmonics.
The usual excuse for those IEC sockets is that we are surrounded by ultrasonic noise from wireless table 'phones, cell 'phones, radio, TV, etc. While all that is true, no-one seems to know what power levels of those disturbances are we talking about. Not the same thing, I hope you'll agree, whether it's a cell phone with a very low power capability, or a ham radio which is not a joke any more.
Agreed on common mode as being the best all around solution. That's what I use.
Per Aspera Ad Astra.
Old 3rd February 2014, 07:20 PM   #11774
RNMarsh's Avatar
Have you measured the CM and DMode on the ac lines to know what kind of filter should be applied?
THx-RNMarsh
Old 3rd February 2014, 07:49 PM   #11775
THx-RNMarsh
All done in 1999-2001. Several versions made, from similar variations to different versions. In the end, overall the best was the version I now use, even if that evolved a bit as well.
I like to periodically set aside the time to muse over them, see if I can come up with something useful. If not, no hard feelings, I still think of it as time well spent.
I do exactly the same with my prototype version of my headphones amp. Yes, it's really good, but I have yet to encounter anything technical which could not be made better still. That's why I always keep the prototype, it isn't pretty and all dressed up, but it alllows me easy access to everything, so I can play with it.
And there's no race like the race to outrun yourself.
Old 6th February 2014, 01:36 AM   #11776
RNMarsh's Avatar
Did you find that there was more CM or more DM on the ac power lines?
And, how did you make the measurements?
What were your noise sources of CM and DM on the ac line?
Thx-RNMarsh
Old 6th February 2014, 11:10 AM   #11777
Thx-RNMarsh
I would like to answer, but I honestly cannot because I don't remember. Measuring much of what I wanted measured required specialized lab equpment which I do not have, so I let a local institute working on such matters do the whole measuring gig.
They did and came back with an impressive set of measurements. And a warning: power quality widely varies across the city of Belgrade alone (app. 2 million pop.), and varies wider still in the 60 km radius.
I was primarily interested in the filter's behavior on the 50 Hz to 100 kHz range. They said that most of the line noise did what it did and was done by around 80 kHz, including harmonics. By then, the filter was down at over -60 dB, while at 20 kHz, the 6 supplied samples were down 29-31 dB, advertised value being "-27 dB or better".
Their findings were very interesting in other aspects. For example, they claimed that PCs were the worst line polluters, followed by some (mind - not all) tube gear, due to thermal noise problems in some designs, and air cons and vacuum clenars were not far behind. With often junk grade motors built into them, I am not surprised.
Subsequent 12 years of practice have validated almost all of their findings.
I think I should talk to them again, in the meanwhile I have gathered more questions, and have changed the filter to a fair degree, perhaps evolved is a more precise description. Time to check up on myself.
Old 6th February 2014, 06:17 PM   #11778
Finally, I managed to get the Current Factory Mk. II under way.
There are several changes, so I attach both versions for review.
The input stage CCS has been completely redone, as this new version provides for a still better CMRR figure, admittedly only 2 dB in comparison with the old one, but I am now down to fighting for every dB I can get.
The second BIG change is that Q1 and Q4 of old, previously 2N5551 bipolars, have been swapped for 2SK170 FETs. Thorsten pinted out to me that there was in fact a very low voltage across these transistors, and it is indeed so, just 3.2V. This is child’s play for the FETs, as they can handle 40V, but the entire circuit gains by lower THD and IM figures, and shows sigificant improvement in its DC stabiility – just as you might expect from FETs. Why I did not see this myself is a mystery to me, but either way, thank you, Thorsten.
Some may ask why the old 2SK170? Well, if any FET has proved its worth in audio time and time again, 2SK170 would be the one. It is still available, unlike many others. And it's cheap enough to buy in some quantity to be able to hand match them to rather close tolerances.
The third change is that the simple zener based CCS for the input stage cascode now has a decoupling (zener to cascode) transistor, which should help remove the last traces of zener noise, theoretically at least.
The fourth change is that I have simply added to the schematic what I said was missing from the first version, and that is the 8th pair of output trannies. They are clearly shown now.
The fifth change is that somewhere along the line I realized that the protection output relay, rated at 16 Amps, will become a bottleneck for any serious listening at any higher volume. Since I would rather die than give it up, there was nothing for it but to add a second relay, doubling the nominal output current to 32 Amps continuous, and 44 Amps in peaks. If anyone is going to need that, it will be Wayne. And, last but not least, this paralleling halves the output impedance of the realys, usually not a problem, but might well be a problem with 1 Ohm loads.
A note here. The schematic shows a total of 3 protection fuses. All 3 are probably not really needed, but there are those why say that just the PSU lines need to be protected, and there are those who feel that a series fuse with the output is the only real deal. I don’t want to be the judge of who’s right, so I leave that to the builder – you decide. You can use only the series fuse, only the PSU line fuses, or all three, your choice. Personally, I’d settle on the line fuses only, but that’s just me.
Overall THD and IM figures are a little down over the first version, but that’s to be expected. Overall, it still uses just less than 26 dB of global NFB, and the open loop full power response is out to 50 kHz. It is still limited to around 200 kHz by the input filter, and I would strongly advise this to remain so. If Wayne wished to lower the cut-off frequency, he can simply increase the value of C12 to wherever he wants.
If this is deemed satisfactory, the next step would be to get in touch with Alex in Romania. The man is WAY more than a competent technician, he is in my view a true artist. Immaculate! I have seen some great PCB artwork in my time, and I believe Alex to be up there with the best. He can supply all required GERBER files to enable local manufacturing almost anwhere, which should be good for Wayne, but we can discuss that along the way. I would say that for somethig like this, 70 microns of copper would be the very least to even think about, but if I could, I’d go for 100 or even 130 microns.
Then we come to most difficult aspect – hands-on development. Given the distance between Wayne and me, and between Wayne and most of us in general, it appears Wayne will have to the hands doing the work, with out wise assistence to back him up.
Obviously, I will help with any and all parts in case there's a supply problem.
If anyone has an idea, this would be a GREAT time to let us know.
I’m off to finish my own Centurion project, which I had to set aside for this one.
Old 6th February 2014, 08:31 PM   #11779
a.wayne is offline a.wayne  United States
Sin Bin
Big centurion or little centurion .... ?
Old 7th February 2014, 07:45 AM   #11780
O tempora, o mores!
That "little" version uses 3 series/parallel 200W devices, and is "little"? Believe it or not, Wayne, but for 99% of us, that is more than enough. In the industry, very, very few manufacturers go that far, the usually best you can hope for are 3 pairs of 130-150W devices.
And if you're called Marantz, and the model is their upmarket 11S, you would use just one pair of 200W devices for nominally 100/200W into 8/4 Ohms. Just how one squeezes 200 Watts of effective power from a single pair is completely beyond me, they must have installed freon cooling in the trannies.
How would such a product survive the IHF power test, I have no idea, remember, 30 minutes of running at 1/3 nominal power prior to measuring maximum power.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
