Sound Quality Vs. Measurements Sound Quality Vs. Measurements - Page 106 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 18th January 2012, 07:34 PM   #1051
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
The amp on the picture shows significant phase intermodulation: different heights of sideband strips.
The Devil is not so terrible as his math model is!
Old 18th January 2012, 07:55 PM   #1052
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Pano View Post
Interesting comments on the "sound" of the amp, too.
Yes ...
Glad you mentioned that , then why the rave? very low distortion .....
Old 18th January 2012, 07:59 PM   #1053
Sin Bin
Wave,
What are we really looking for here as depicted in the below screen shots, what is good better , best !!!!
Old 18th January 2012, 08:24 PM   #1054
Wavebourn's Avatar
Yes, low level of harmonics generated by intermodulation, but 5 microseconds of phase intermodulation is already audible as something artificial. Especially on stereo, when it means already uncertain stereo image localization. It sounds like paradox, but much easier measurable effects caused by Doppler effect in speakers is less audible! My understanding is, because human perception got used to mechanical alterations during long time of evolution, while electrical errors are something new in the recent life of each individual.
Old 18th January 2012, 08:29 PM   #1055
tvrgeek is offline tvrgeek  United States
On my learning front that was initiated by the question of this thread, I have three questions for today:
Conventional input stage. LTP etc. The major value of feeding the legs with a current mirror is that when using only one output, it is hard to predict/manage the impedance of the second stage. Forcing balance with less than perfect diff transistor is secondary. The current mirror forces balance in the diff pair regardless. Am I starting to get that correct? Second, I have not seen the Wilson current mirror in any of the schematics I have. Is it past the diminishing returns point? Thirdly, if I power the input stage from a regulated supply, is there as much advantage to have a CCS in the tail? I can read the books, but they don't answer questions yet. It seems to me I have seen comments something like "the CCS measures great, but does not sound the best" which does not make complete sense but I am sure there are a hundred smaller factors of which I know not.
If I put all of these questions together, it leaves a fourth bonus question: If one uses a matched pair i.e single die, for the current mirror, is the diff pair as critical? This would leave open the possibilities for JFETS not available as monolithic pairs.
Old 18th January 2012, 08:32 PM   #1056
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
This is where subjectivists and objectivists meet. I understand Fremer does his listening evaluation before Atkinson does his measurements, so thumbs up for his ears.
If anything, it also shows that further reduction of measurable deviations from perfect, may still pay out in acoustical terms.
The interesting thing though is that other amps that measure badly can still sound great. I don't know how to link to that article in Stereophile about the WAVAC, but it doesn't do well on the test bench, that is one thing I remember. However, the listening tests were very positive, and there sonic quality is substantiated by other samplers. I remember a recent post by John Curl mentioning WAVAC as one of the highlights of the show.
So, there are two possibilities here. Either the WAVAC is a perfect effects box. Or, amps like the WAVAC and the Soulution do something else right, something which still evades measurement, but which is essential in producing the most natural sound without audible artifacts.
vac
But from now on I will be discrete about it.
Old 18th January 2012, 08:57 PM   #1057
vacuphile's Avatar
Originally Posted by a.wayne View Post
Wave,
I would say the first picture is the best because it show the largest randomness, i.e. noise, versus a repetitive distortion residue. Secondly, the repetitive part seems to be mainly 3rd order distortion if I counted right, not that much of a problem. Interesting is that the repetitive part of the residue is neatly phase aligned with the fundamental. Could that be a clue to something?
vac
Old 18th January 2012, 08:58 PM   #1058
Wavebourn's Avatar
Of course it does!
For example, line array of small speakers from floor to ceiling sounds much more natural than traditional speakers with single drivers. For the same sound pressure drivers in line arrays do much shorted excursion, that greatly reduces distortions generated by them. And so on. The point is, efforts have to be applied where they lead to audible results, instead of lowering down THD of power amp from 0.01 to 0.001% where such reduction is inaudible, but means to reduce THD cause another audible artifacts.
Old 18th January 2012, 09:14 PM   #1059
Sin Bin
vac
With the third one being the worst ...? OK so better to have the random noise than for it to follow the signal as in pic 3 ...?
Old 18th January 2012, 09:15 PM   #1060
"So, there are two possibilities here. Either the WAVAC is a perfect effects box. Or, amps like the WAVAC and the Soulution do something else right, something which still evades measurement, but which is essential in producing the most natural sound without audible artifacts."
I vote for number two. That of course does not preclude amps that measure very well from also sounding very pleasing.
Sound Quality Vs. MeasurementsHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
Sound Card for Measurements Marik Solid State 2 2nd January 2012 08:59 PM
Sound Card Recommendations (For Audio Measurements) dchisholm Equipment & Tools 5 16th July 2011 09:40 AM
How to protect sound card during amp measurements? okapi Everything Else 13 2nd September 2008 03:06 PM
Sound cards - test and measurements jackinnj Everything Else 2 5th July 2003 03:02 PM
Copyright ©1999-2017 diyAudio
