The Lounge A place to talk about almost anything but politics and religion.
The speed of light is NOT constant
Closed Thread
Old 27th September 2011, 12:29 PM   #121
lieven is offline lieven
lieven's Avatar
Talking waveguide, energy distribution
could be an explanation in anology of our beloved sound-waves, maybe...
Old 27th September 2011, 05:05 PM   #122
chris661 is offline chris661  United Kingdom
chris661's Avatar
Maybe the speed of light in rocks 'n' stuff (the 'n' stuff being anything else between the two devices) is faster than the speed of light in a vacuum?
If this was the case, there would be no problem.
Old 27th September 2011, 05:37 PM   #123
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Nope, speed of light in solids is always < C
But from now on I will be discrete about it.
Old 27th September 2011, 06:28 PM   #124
DF96 is offline DF96  England
I assume that they have taken account of any gravitational and rotation effects.
Old 27th September 2011, 06:58 PM   #125
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Maybe it isn't relativity that needs reexamination, but instead our idea of the speed of light is off (by approximately 0.0025 percent)?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 27th September 2011, 07:11 PM   #126
Interesting point, but I think GPS would fail if true.
Old 27th September 2011, 08:14 PM   #127
Rodeodave is online now Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Now if we could only find a way to put a charge on these "neutrinos", and build some sort of "neutrino" vacuum tube, then with a circuit large enough we could probably manage to apply negative feedback at the point when the record currently playing was recorded, and thus compensate for dreadful remastering.
But I could easily be mixing up some facts though, so don't give it too much thought.
Gravity - Making the G since 13.7 billion B.C.
Old 27th September 2011, 10:36 PM   #128
sofaspud's Avatar
DF96, you know much more about this stuff than I do, but I was thinking the distances involved in GPS aren't great enough to reveal the error.
I considered the brief second page of the OP article very important to the whole. In monitoring the supernova, they "arrived within hours of each other." It isn't explicitly stated which arrived first, but I'm assuming the neutrinos lagged in that case, due to it being presented as a contradiction to this latest experiment. Definitely some strange and interesting things going on.
Old 28th September 2011, 12:56 AM   #129
Joseph K is offline Joseph K  Hungary
The neutrinos preceded the light, ~3hours. But if You look it up, it is well described, and was expected like this.
Shortly: it took ~ 3 hours for the the detonation shock wave to reach the surface, and generate light. The neutrinos got a "head start", flying directly through of that superdense material.
With this 0.0025 % difference, they would have been ~4 years ahead, if it were valid even in that case. Obviously not..
Or.. who knows.. If there had been a primary neutrino signal 4 years earlier, I think it's close to zero the chance to dig it out of the general noise. I'm not sure if there were at all any detectors operative at that time. Real time neutrino detectors are not simple or cheap toys, and only proliferating recently.
{Kamiokande original only started up at 1983 april. Supernova happened in 1987 february. That is 1987-4 --> 1983 february..}
Ciao, George
Old 28th September 2011, 01:22 AM   #130
Ok, looked up - the other two detectors were operational also in 1983.
Though, if once in a year, at some moment, they had an abnormal signal, without any corresponding supernova event.. certainly up to now nobody was doing this kind of backward searches..
Closed Thread
The speed of light is NOT constantHide this!Advertise here!
Cosmological constant.... mikeks The Lounge 402 21st February 2005 04:27 PM
Constant current PRBS Pass Labs 6 24th March 2002 01:49 PM
Copyright ©1999-2017 diyAudio
