The Lounge A place to talk about almost anything but politics and religion.
Where do you carry your cellphone, and how often do you use it?
Old 13th August 2011, 08:59 PM   #21
DualTriode is offline DualTriode  United States
Hello,
Ralph Lauren, Bob Marley, Gene Siskel,
George Harrison, François Truffaut, Robert Moog, Lee Atwater, Ethel Merman, Bobby Van, Raymond Carver.
Names of people you may have heard of all with brain cancer all with cell phones.
http://en.wikipedia.org/wiki/List_of...tumor_patients
The study may not be sponsored by the National Institute of Health or Blackerrry but is on going today most every teenage kid in America sleeps with his Iphone under his pillow. We will see!
DT
All just for fun!
Old 13th August 2011, 11:00 PM   #22
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The cell phones of 10+ years ago transmitted with a power level of up to 1.5 watts. The old bag phones and "transportables" had even more power. There was no active power control. Even if you were standing next to the tower the phone trasnmitted at full power. The old analog phones were constantly emitting power as long as you were in a call even if you aren't talking. The "dose" of RF energy averaged over time was much stronger than it is today.
Modern cellular base stations will collect all the RF energy in a given frequency spectrum, down convert it, then stuff it all into a fast A/D converter. The converters are 12 to 16 bits wide so there is a limitation on dynamic range. For this to work all of the signals hitting the base station in the sampled frequency range must have the same relative strength. One excessively strong signal will consume all of the converters dynamic range. In all modern cellular standards all phones on a given frequency range are told reduce their power to that of the weakest incomming signal.
In an urban environment there are cell towers everywhere, but only so many frequencies assigned to cellular phone service. Thus the frequencies are reused, ofted as close as every other or every third tower. This means that a phone with too much power will interfere with a neighboring cell site, so the power is kept low to prevent interference.
So for purely economic reasons the great toasted brain experiment has had the conditions changed slowly over time in favor of the users head. Now when you stuff the phone under your pillow and block the path to the tower, what do you think the phone does? And where do you think that extra RF energy goes? The pillow isn't going to absorb it.
Don't think that I advocate trashing your phone. Nor do I believe that the phone definitely causes cancer, nor do I believe that it isn't possible. In any controlled experiment you try to minimize all variables except the one that you are trying to observe. The "cell phone causes brain cancer" statement currently has far too many variables to draw ANY definite conclusions.
I work with two way radios with much higher power levels, up to 10 watts in a hand held device and 100 watts in a car mounted mobile. Definite conclusions have been reached and the power levels for the higher frequency bands have been reduced over the 30+ years that I have been involved. Strict guidelines have been drawn up in regards to installation and use of high powered transmitters.
Just use common sense with your phone and limit excessive use whenever possible. Step outside or go near a window to have a long conversation. I even know where the cell sites are that serve my house and work locations and go to windows that face the tower. With the cell phone carrier that I use, that is necessary to avoid dropped calls.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 13th August 2011, 11:37 PM   #23
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I found a problem with a cell phone in my pocket.
After many hours of it being there I started getting a numb leg.
I chose to ignore it for a good few weeks but eventually it got worse.
So I stopped putting it in my pocket but the numbness is s till there but very slight. Been like that for years now.
I dont know if it was the pressure of the phone on my leg or the RF that caused the problem.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 14th August 2011, 12:09 AM   #24
BudP is offline BudP  United States
BudP's Avatar
Not to worry Nigel, you are just dying of natural causes.
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 14th August 2011, 12:13 AM   #25
Odd thing is my mother died partly from cancer of the left hip which is the same leg I get numbness in.
Old 14th August 2011, 12:45 AM   #26
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I had exactly the same experience! It was very slight, and rather kind of pleasant.
By the way, with RF everything depends on frequency and peak RF power more than an energy absorbed by tissue. As I wrote before, for my 10.7 GHz 20 mW device safe distance was 20 centimeters. I don't remember all details, how I calculated it, itg as 30 years ago, so can't tell about frequencies near 1 GHz, and radiation pattern less narrow that used in my device. But numbness in the leg can be caused by cellphone in the pocket.
I remember reading the story several years ago, when one lady sued some cellphone manufacturer because when cellphone sandwiched between human fat and sofa could not connect to station overheated battery burst in flame right in her pocket.
The Devil is not so terrible as his math model is!
Old 14th August 2011, 02:39 AM   #27
Hello,
The answer to the original question, normally my cell phone is in the bottom of my laundry hamper. The phone is company issued and I occasionally need to make calls when I am on the road. The phone stays in the car when it is not at the bottom of the laundry hamper. In or around the car I use a visor mounted voice activated Motorola Bluetooth. Sometimes I hand hold the Bluetooth (not really hands free). The cell phone is used very little, perhaps 10 minutes a week. I do still wear a wristwatch.
DT
All just for fun!
Old 26th August 2011, 08:11 AM   #28
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
In the course of my previous job as a broadcast engineer for a PBS station I got shipped off to an RF safety cert seminar to become a certified card carrying porkchop. The FCC is VERY serious about RF site safety and one of their biggest focus points now is cell site location and safety. Anyway, got oodles of RF safety lit and studies of ionizing RF energy. There was one correlation study between cellphone use and brain cancer. The correlation was linked to indications that the brain cavity is a 2x freq resonant RF cavity that concentrates and partially amplifies the low end analog cell freqs. BUT the only real medical cases existed from the days of the earliest brick phones that pumped out multiple WATTS of energy that were held directly against the head by very heavy phone users.
Bottom line was reduce the power -as all have now done- and get the dang thing away from your head... particularly if you're in an old analog service area.
I use speakerphone wenever possible and bluetooth if at all in a car.
As to running a magnetron outside an oven, an obvious cantidate for a Darwin award.
Doc
Noli timere problematum affigit
Old 26th August 2011, 05:35 PM   #29
Wavebourn's Avatar
I don't understand why they try to prove CANCER resulting from exposition to RF, but not just ANY DAMAGE? When you cook a chicken in microwave, do you EAT CANCER?!
Old 26th August 2011, 06:01 PM   #30
benb is offline benb  United States
Only if the microwave is powered by electricity from a nuclear power plant.
Seriously, I read Omni Magazine when it first came out circa late 1970's. There were little quotes and factoids at the bottom of every column of text. I recall one saying that "one out of five people believe that electricity produced by a nuclear power plant is radioactive."
Where do you carry your cellphone, and how often do you use it?Hide this!Advertise here!
electrical switching from cellphone to ipod? harliquin Construction Tips 1 4th October 2010 06:33 PM
CH250 Airport Carry On aud1out Everything Else 3 8th March 2008 08:26 AM
How much weight does ABX carry? Wellfed Everything Else 24 19th September 2004 06:17 PM
PartsExpress to soon carry Usher Drivers.... Hybrid fourdoor Multi-Way 4 2nd July 2004 07:29 PM
Copyright ©1999-2017 diyAudio
