The Lounge A place to talk about almost anything but politics and religion.
Annoying explorer window in Win2K
Old 24th August 2003, 11:29 PM   #11
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Originally posted by Netlist
Just to let you know my problem is fixed:
The troublemaker was Realtray from RealPlayer.
I deleted the Realtray entry in the run section, rebooted and all was fine.
Although there is no way I can see a link between Realtray and Explorer.
/Hugo
Found something for you, Rodd:
http://support.microsoft.com/?kbid=315054
/Hugo
Hugo,
Thanks for the info. I have a question. Where did you delete the Realtray entry?
Rodd Yamashita
Old 24th August 2003, 11:44 PM   #12
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Rodd,
From the desktop, go to start, run, type regedit and push the Enter key.
That will open the registry editor.
Got to the top and look for the following; HKEY_LOCAL_MACHINE.
Select this folder and drill down to the subfolder;
SOFTWARE\Microsoft\Current Version\Windows\Run
There you'll find all that is started up automatically.
Delete the Realtray entry.
Close regedit and the problem should be history.
Frank
Old 25th August 2003, 04:29 AM   #13
roddyama's Avatar
Hi Frank,
Thanks. That takes care of that one. Now I have to work on the other anomaly. I do have some @Home remnants that I need to clean up as indicated by Hugo's link.
Rodd Yamashita
Old 26th August 2003, 02:17 AM   #14
fdegrove's Avatar
Hi Rodd,
The link Hugo provided holds all the instructions you'd need...still if you need further help, just ring the bell.
While I'm at it...once you have everything working as should, please DO install IE 6.0, it's really much better than 5.0.
After that run Windows Update to get all the security patches and updates ( get used to it, it's Mickeysoft after all) and enjoy having countless browser windows open.
Frank
Old 26th August 2003, 06:29 AM   #15
roddyama's Avatar
Thanks Frank,
My software maintenance is so pathetic. I will get to it soon.
Rodd Yamashita
Annoying explorer window in Win2KHide this!Advertise here!
Help on the Design Explorer DXP alexandar888 Software Tools 0 8th May 2009 12:24 AM
Audigy II NX at 24 bits under Win2K ingrast Digital Source 2 4th October 2006 03:58 PM
Internet explorer 6 ash_dac The Lounge 17 10th July 2006 07:05 PM
Internet Explorer 6.0 Christian Everything Else 154 10th December 2002 10:18 AM
PCAD2001 PCB editor crashes Win2K MRehorst Everything Else 1 27th July 2002 07:32 PM
