The Lounge A place to talk about almost anything but politics and religion.
Old 19th February 2011, 09:03 PM   #9901
simon7000 is offline simon7000  United States
Originally Posted by SY View Post
Well, Ed, disagreeing with you is always a pleasure. Best case, I learn something new. Worst case, you learn something new.
"PVA" is an ambiguous term- it can mean "polyvinyl acetate" (which is a component of the record fomulation and not used as a release- it's a glue) or "polyvinyl alcohol." The acronym "PVOH" has no such ambiguity, which is why we polymer geeks use it in this context. The "OH" indicates "alcohol," since the hydroxyl group is the defining feature.
PVOH is absolutely soluble in water, and absolutely will wash off. The high solubility is one reason why its use in food contact packaging is restricted to inner layers in a multilayer system.
If the hypothesis of a bumpy record with PVOH as Bondo is correct, then wet washing will make records noisy. It doesn't. End of hypothesis.
Well that would leave the moisture has caused a non-uniform movement in the records surface or you have deposited something.
So what is your hypothesis?
Or do we need a chemical engineer to do rate equations?
Bill that monk from Occam England had some rules on explanations.
Old 19th February 2011, 10:45 PM   #9902
On Hiatus
SY's Avatar
Well, like I said, my hypothesis is cratering of the vinyl from some sort of skid-slam mechanism. Wet play after damage doesn't show the damage well because the craters are more or less "filled in" by the fluid, which doesn't undergo shear. A micro examination of a formerly wet-played disk would determine if that hypothesis is valid or incorrect.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th February 2011, 11:03 PM   #9903
Soundminded is offline Soundminded  United States
Originally Posted by Joshua_G View Post
As I wrote above, you believe you see things in perspective, while to me, before you'll demonstrate your theories in practice, your words are empty.
You don't get a United States patent for a revolutionary type of sound system for empty words. And I do have a working prototype.
Old 19th February 2011, 11:09 PM   #9904
On Hiatus
SY's Avatar
Your idea might be the greatest thing ever, but a patent or lack of one is irrelevant. Of course, so is going commercial- there's lots of great diy stuff, lots of crappy-but-hyped commercial stuff.
A patent can be substantial- or it can be "empty words."
Old 20th February 2011, 12:01 AM   #9905
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Well said.
Old 20th February 2011, 02:19 AM   #9906
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by simon7000 View Post
Sy,
Scott,
The interesting unasked or unanswered question always was, "Was anything or anyone else aboard his submarine?"
ES
Nope, I was there tonight he was DJ at the USO in Thule Greenland during the Vietnam war, as hs says "put me anwhere there is no shooting". He has the largest collection of stoner rock you could ever see (the liner notes are a real treasure). We pondered the water question over a bottle of 1975 Lascombes and came to no conclusion other than only the Pickerings seem to stand up to the abuse.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 20th February 2011, 02:36 AM   #9907
hitsware is offline hitsware
Thank You,
Amar .........
Old 20th February 2011, 04:37 AM   #9908
TerryO is offline TerryO  United States
TerryO's Avatar
Thank You,
Amar .........
+1
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 20th February 2011, 04:51 AM   #9909
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
This whole idea of 11% direct and 89% indirect sound was postulated by Dr.Podzus back in the 40th. His nephew Manuel Podzus has shown me an old picture with a spaeker with multiple wideband drivers also developped by Dr. Podzus so his ideas where simply stolen.
Old 20th February 2011, 05:13 AM   #9910
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Yes, you can. It's done all the time. Hell, they're still issuing patents for perpetual motion devices.
se
The Audio Guild
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
