The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 20th November 2017, 03:23 PM   #97621
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by keantoken View Post
Jan, the last paragraph in my post explains why Cds doesn't load the circuit as a whole, only the MOSFET. You get the same output gain until the MOSFET saturates enough to disrupt the bias system.
But looking from the point of view of quiescent bias current for the MOSFET, you need to account for ther 'load current' throuhgh Cds, right?
So, if I want to calculate the quiescent current (class A) that I need to swing the load cap through the full voltage range, I have to calculate for Cload + Cds + Cdg, right?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 20th November 2017, 03:42 PM   #97622
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Jan
The current charging Cds subtracts from the drain current and Cds ends up getting charged by some of the pullup current (to the first order). I thought this was intended as an open loop circuit? I either case the DC bias needs to be enough to supply the max displacement current in Cds to remain well behaved.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 20th November 2017, 06:13 PM   #97623
jan.didden's Avatar
That's what I thought. Interesting case when the load capacitance is largely caused by the intrinsic Cds and Cgs. I was thinking, well I just put two in parallel but obviously that has a very small advantage only in such cases, not worth the effort.
And it will be closed loop.
Jan
Old 21st November 2017, 04:23 AM   #97624
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Jan
some depends on the cascode series gate resistor R11 value..... compare with zero Ohms and 1 meg. The degree of effect of the Cdg and Cgs and that R11 ---- assuming gate bias source Z is zero.
THx-RNMarsh
Old 21st November 2017, 05:16 PM   #97625
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
No, professional division (BSS, dbx, Lexicon, DigiTech).
I would like to stay corrected: Crown also Crown Audio files notice of first half of layoffs
Only four years ago: Crown Audio announced plans to expand its operations that will lead to 44 new jobs in Elkhart
Old 22nd November 2017, 02:38 AM   #97626
RNMarsh's Avatar
It seems from experience that plans like expanding all go out the window when the parent company gets bought out. Especially affected are any duplications.
-RNM
Old 22nd November 2017, 02:18 PM   #97627
jan.didden's Avatar
OK, got further and accomodated the Cds & Cdg current. Circuit runs on the sim as expected.
But (there always is a but) I assume that that displacement current does not cause dissipation in the device. Is that correct? To calculate the dissipation I should account for the total device current but subtract the part that is due to the 'shunting' parasitic capacitance current to get at the current that needs to be multiplied by the device voltage (RMS fashion) to determine the dissipation. Yes?
Jan
Old 22nd November 2017, 02:30 PM   #97628
dadod is offline dadod  Croatia
dadod's Avatar
Jan
Jan, do you use Spice (LTspice) simulator. It should do all that if models are correct.
Damir
Old 22nd November 2017, 02:47 PM   #97629
Not necessarily, you want the true power in the FET which will depend on the phase angle of the net current and voltage. As Damir said this should be built into any simulator, it's fundamental.
Power in AC circuits
Old 22nd November 2017, 02:58 PM   #97630
jan.didden's Avatar
Damir & Scott, beg to differ. Yes, LTspice gives me dissipation in any color I want, but the way I see this is as follows.
The current LTspice 'measures' is based on the mesh current flowing (in the case of my MOSFET) from D to S. But intrinsically to the device are the capacitances like Cds. So if I ask LTspice to .measure the dissipation as the product of device current and device voltage (RMS fashion) the Cds current is included, although it does not (I believe) contribute to heating.
Edit: do you mean that the phase shift of the device current to the device voltage, as result of Cds, is automagically taking care of this through the complex calculation?
Jan
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
