The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 3rd February 2011, 02:13 PM   #9401
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Any thoughts on how to build a sonically good ic op amp, or what is missing in existing ic op amp designs ?.
Eric.
I believe not to believe in any fixed belief system.
Old 3rd February 2011, 02:29 PM   #9402
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by Soundminded View Post
The mathematical model for cables of all types is one of the most well understood and highest correlation formula when compared to testing data we have. I'm referrig to the "Telegrapher's Equation." It gives the lump sum parameter equivalent of the distributed parameter network of a cable.
The lumped sum parameter equivalent is only an approximation. It pays no heed to the line length, prop velocity, or impedance mismatch at the load. While the equation is well understood, it's application to audio loads and frequencies is terribly mis-applied and mis-understood.
The world standard for wire is Belden. There is nothing about wire that is known that Belden doesn't know.
I concur, Belden is the best. There is a lot however, that they do not know about wire. Try buying 75 thousand feet of low smoke, zero halogen, radiation resistant cable tray rated 2/0 single conductor...
And their papers on t-line theory use approximations..Still, they are the best out there.
The aftermarket audiophile wire industry plays on ignorance, fears, and hopes of its prospective customers to sell solutions to problems that don't exist.
Or, possibly, problems that have not to date been discernable using standardized blind testing. I remain open to that possibility.
Originally Posted by mrfeedback View Post
The standard lump sum parameter description does typically not include dielectric properties.
Actually, they do for first order numbers. Specifically, the capacitance and cable impedance are. But second order effects such as absorbtion, no.
Agreed on Beldon - the beauty of Beldon is that their cable parameters are defined and guaranteed allowing predictable design and performance.Eric.
I do wish however, that they'd include inductance per foot for all their cable. They've been tending to include cable Z and cap per foot, and we have to re-calc to get the inductance.
I am certain that there are audiophile speaker cables manufactured with such high shunt capacitance and poorly designed solid state amplifiers that are so unstable that the combination will form a tank circuit that will send the amplifier into spontaneous ultrasonic oscillation.
Actually, "poorly designed amplifier" requires some slight re-statement. If the amplifier is hot enough that tweeter unloading causes sufficient phase shift before unity gain, is it the designer's fault? The designer may have had speed/bw requirements that did not include stability in all regimes.. I would blame the one responsible for the initial design requirements.
Note I did not say excessive capacitance. It is because the tweeter impedance rises sufficiently well above cable z before unity gain. Cable capacitance is not the real culprit, but the load mismatch is.
Cheers, John
Old 3rd February 2011, 02:43 PM   #9403
simon7000 is offline simon7000  United States
Originally Posted by john curl View Post
Many attribute it to arbitrary factors, but I think is is overlooked factors, not yet easily measured with test equipment made with the same electronics that we have already found wanting.
I am back after a short break, I see most of you seem to never take a break
Pavel,
If I measure the Cepstrum of a directly heated cathode vacuum tube amplifier without global feedback and a modern well designed solid state unit, do you think I would find time domain information that might show a difference?
ES
Old 3rd February 2011, 03:02 PM   #9404
mrfeedback's Avatar
Linn amplifiers will oscillate when driving capacitive cable.
Indeed their recommended cable is a heavy duty twin ribbon cable with conductors about 12mm apart - I suspect this cable is 300 ohm twin feeder cable for transmitter application.
Eric.
Old 3rd February 2011, 03:23 PM   #9405
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
This year at CES and The Show, a great deal of emphasis was placed on vinyl reproduction and vacuum tubes.
I take this as the high-end has given up trying to trickle down any of their ideas into more affordable mainstream products and has decided to serve their tiny market of followers with ever more ridiculously priced, as Kantor says, fetish objects.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 3rd February 2011, 03:29 PM   #9406
jneutron's Avatar
Eric.
Actually, the statement is only partially correct. The distinction is meaningless to the general public, as they normally have no control over the load characteristics at high frequencies. To people who do e/m for a living, the distinction is huge.
So..
Linn amplifiers will oscillate when driving a capacitive cable that is terminated in a load which decouples at higher frequencies.
A linn amplifier will NOT oscillate when it drives the exact same cable when that cable is terminated in a load which matches the cable impedance up to the unity gain point of the system.
Cheers, John
ps.. holy mackeral, that orange was horrible..red not much better...blue it is..
Old 3rd February 2011, 03:30 PM   #9407
Cheers, John
The same might be said for speakers with regions of pathologically low impedance, the requirements for .1dB error from cable resistance might come into play.
Old 3rd February 2011, 03:43 PM   #9408
jneutron's Avatar
Agreed. Iff .1dB is of significance. Otherwise, it's just a number. When the termination impedance falls below line z, the system starts to look inductive. While I do have cases where inductance can cause instability, it's pretty much limited to load inductances outside consumer interest, anywhere from 5 to 70 henries.
What I am speaking of with hf instability however, is based in T-line theory. I do not have sufficient understanding of electronics to even think about a resistive divider...perhaps next semester??
ps..happy belated bday, you old guy...
Cheers, John
Old 3rd February 2011, 03:52 PM   #9409
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by simon7000 View Post
Pavel,
ES
Ed,
most probably yes, how about interpretation of the result?
Old 3rd February 2011, 03:55 PM   #9410
Johnloudb is offline Johnloudb  United States
Johnloudb's Avatar
Originally Posted by Scott Wurcer
"I firmly believe that any man's finest hour, the greatest fulfillment of all that he holds dear, is that moment when he has worked his heart out in a good cause and lies exhausted on the field of battle - victorious."
Scott, I see you're you're all prepped for the super bowl.
Or are you just communicating the deeper meaning here?
My Website: Hyperacusis, Tinnitus, My Story
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
