The Lounge A place to talk about almost anything but politics and religion.
Old 16th January 2011, 11:12 PM   #8851
1audio is offline 1audio  United States
Originally Posted by Steve Eddy View Post
Maybe for recording flutes?
se
Makes a good intrusion detector if attached to a fence.
Demian Martin
Product Design Services
Old 17th January 2011, 12:06 AM   #8852
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
se
The Audio Guild
Old 17th January 2011, 12:29 AM   #8853
Soundminded is offline Soundminded  United States
Originally Posted by scott wurcer View Post
>the DBS creates an electrostatic field that saturates and polarizes the molecules of the insulation to minimize energy storage in the dielectric.<
Of couse this maximizes the energy storage.
The insulation between the plates IS the dielectric. What is this technobabble about anyway, a DC offset voltage to bias the plates away from zero volts? What is that necessary? Is there supposed to be an inertial force to overcome in the dielectric to generate an induced field as a dual to the magnetomotive force required to generate an induced magnetic field in the ferrous core of an inductor?
Old 17th January 2011, 12:41 AM   #8854
Pano is offline Pano  United States
Pano's Avatar
Darn it Steve, I really want to build one now! No idea what for, but it just seems really cool. Wonder how flat strip vs round cable would work out?
Old 17th January 2011, 12:41 AM   #8855
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by KBK View Post
I'm guessing the point is to get the diode like molecular polarization flip (zero point or thermal noise) point to cease to exist as part of the problem.
Why isn't the polarization continuous through 0? References? No one mentions that the force between the conductors is totally rectifying.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 17th January 2011, 01:29 AM   #8856
Heavens to Van der Waal's forces. The one with the greatest resistance to deformation and therefore fluctuating capacitance resulting from geometric distortion in the face of Van der Waals forces wins. I guess that would be.....ceramic.
Old 17th January 2011, 02:03 AM   #8857
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by simon7000 View Post
I did not mean this as a trick question. The foundation of Fouier's theorem is that any periodic wave form can be considered as a series of sine waves.
There are two types of problems with this approach. Waveforms such as noise are not periodic.
Yes.
Secondly there are periodic waveforms that are not properly sampled in normal practice.
Here do you mean they're sampled over a non-integral number of cycles?
When I look at FFT displayed data I often see the "DC" or lowest frequency "bucket" changes on repeated tests of the same experiment. This can be noise, actual DC change, or partial sampling of a very low frequency waveform.
It doesn't even need to be very low frequency. Its most likely you've got a partial cycle of a higher frequency signal in there. That's what windowing's for (or as some prefer to call it, apodizing). Then the subjective element comes in - what windowing function do I choose? I'll generally go for Blackman-Harris myself, but even that has various options (number of terms for example - its a family of windows). According to what we're looking for, we'll choose the windowing function accordingly. Or alternatively, acquire only integer numbers of cycles which then means we know what we're looking for before we do the acquisition. I've worked in machinery vibration diagnosis incidentally, so have some experience here - its possible to make all the stuff you're not interested in totally disappear into the noise given enough averages. That's only possible when the sampling frequency is somehow phase-locked to what's doing the signal generation - a kind of 'lock-in amplifier' (explained in Horowitz and Hill if you're interested).
So the question is are there other cases where the theorem is not properly applied?
I'm not clear what your question here means.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 17th January 2011, 02:10 AM   #8858
Steve Eddy's Avatar
I believe the impetus behind it is to overcome the effects of dielectric absorption, though I'm not aware of anyone demonstrating it being a problem with audio cables.
se
The Audio Guild
Old 17th January 2011, 02:14 AM   #8859
abraxalito's Avatar
I find it fascinating that a patent I was issued in 1994, 5,307,416, describes this technique. The merits of it and its audibility are a separate issue.
That's the very issue that prompted me to post up the quote. I have no issues with the theory behind the dielectric biassing, just cannot imagine how that could translate into improvements in 'color' via a digital cable. Hence my curiosity dry-up.
However, believing that a digital link won't be influenced by various external effects is naive. If it is self clocking it can be very affected by cables issues. The second question is whether the jitter and noise will be audible. Again the issue has not been fully resolved but its easy to see that a digital link is a clear path for high frequency noise to enter the analog stages with possible effects.
Yes, in which case the equipment downstream has not been competently designed. So let's fix the problem in the design, rather than require expensive cables to band-aid it for us eh? Here's where I am somewhat curious - do the guys who hear these differences with digital cables ever feed back their findings to the manufacturer of the DAC? Or do the DAC designers deliberately sell poor designs so as to help make money for the cable vendors?
I have looked for distortion in cables with a -170 dB floor and found nothing. However this may be the wrong way to look.
Yes.
Old 17th January 2011, 04:19 AM   #8860
John C tells me that he has repeated his measurements of cables and saw the same results (with one of my ST analyzers). I need to try it again.
Noise isolation with digital connections is much harder that it may first seem. As the frequencies get higher it takes less to couple them. Also the noise can find many ways into the circuitry, not just the obvious ones. Even more likely to be an issue is coupling between cables independent of the box they are connected to.
For the Physicists reading:
I don't have a good enough understanding of electrostatics to say what happens when a conductor is between two conductors that have a potential. If the conductor is not connected to them I believe it will adopt a potential relative to them proportional to the capacitance. If its connected to one of the conductors then it won't have a potential to the conductor its connected to. In the second case would the lack of a potential between the conductors be affected by the electrostatic field from the conductor with a potential? If so, how and how much?
This is the situation with the Audioquest design as far as I can tell.
Demian Martin
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
