The Lounge A place to talk about almost anything but politics and religion.
Old 24th December 2010, 01:21 AM   #7901
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by pooge View Post
That's assuming you use the same SPACING for each, which is not likely for a PRACTICAL twisted pair vs. a coax, for example.
But comparing twisted pair to coax is going back to apples vs oranges once again. Coax to some degree also gets cancellation of fields, assuming that the construction is indeed perfectly axisymmetric (which is never is in practice of course).
But since, as usual, you HAVE to have the last word, you can make up another scenario and argue with yourself.
Irony meter off scale - you invented the above scenario with coax, Steve was confining his statements to only twisted and paralleled pairs
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 24th December 2010, 01:57 AM   #7902
john curl is offline john curl  United States
john curl's Avatar
In any case, balanced operation is next to useless, unless you are in a high interference environment when it comes to phono operation. So let us continue on single ended operation.
"Condemnation without Examination is Prejudice"
Old 24th December 2010, 02:11 AM   #7903
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Have you decided on the input Opamp ?
Old 24th December 2010, 02:59 AM   #7904
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by hitsware View Post
I have a friend (whos ears I trust very much)
(way more than mine)
He says right angle traces sound bad because
of the "lack of smoothness" brought on by the
electrons changing direction so abruptly.
And this is just the sort of thing one would come up with who had little more than a sixth grade science class understanding of conduction in metals.
Amazing how things sound better even though reason given for it is so off base.
se
The Audio Guild
Old 24th December 2010, 03:30 AM   #7905
On Hiatus
SY's Avatar
D3a.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th December 2010, 03:40 AM   #7906
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mm, you sure Frank Bl÷hbaum didn't buy up all Deutsche Post triode + pentode valves ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 24th December 2010, 03:49 AM   #7907
Yes, i am sure.
Old 24th December 2010, 04:09 AM   #7908
john curl's Avatar
Joachim, the exact IC op amp is not necessary to define at this moment. Just low noise type.
Old 24th December 2010, 04:18 AM   #7909
jlsem is offline jlsem  United States
jlsem's Avatar
The real problem is, because they are traveling so fast, the electrons fly off the ends of the traces because they are unable to make that sharp turn.
John
Old 24th December 2010, 04:21 AM   #7910
So, dou you think it is a good idea to make the feedback resistors the same impedance as the impedance of the cart. ? Whould not be the lowest noise though, and the cart, being low impedance whould not provoke common distortion much anyway.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
