The Lounge A place to talk about almost anything but politics and religion.
Old 28th October 2010, 09:24 PM   #6401
john curl is offline john curl  United States
john curl's Avatar
Yes, usually retorts in defense of someone else being attacked by ---.
"Condemnation without Examination is Prejudice"
Old 28th October 2010, 10:13 PM   #6402
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
Originally Posted by john curl View Post
Of course, these ceramic caps, being ....
the McMartin 'ma20' amplifiers have the 'Z5U' Dielectric.
as they work and sound, as well as they do,
i've been apprehensive to change anything.
Old 28th October 2010, 10:17 PM   #6403
john curl's Avatar
So long as you are happy, Tomtt. And I will stick to my 2 buck chuck wine, because it works for me.
Old 29th October 2010, 02:45 AM   #6404
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
That's fine John, how about a blind shootout SY tells Belle Helene from 2 Buck Chuck and you tell the difference between Dale RN55C and naked Vishays. No peeking.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 29th October 2010, 03:16 AM   #6405
john curl's Avatar
Sound differences seem to need a different test than taste, BECAUSE the music is always changing, and taste stays the same.
Old 29th October 2010, 03:27 AM   #6406
pooge is offline pooge  United States
Don't agree with that. My taste in women changes with the weather.
Old 29th October 2010, 08:37 AM   #6407
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I had a double blind date with a belle Hélène once, but she turned out a bucking Chuck.
Hard to differentiate if not wire-wound.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 29th October 2010, 09:40 AM   #6408
Joao@AltheaMusica is offline Joao@AltheaMusica  Switzerland
Sonic reasons are not allowed to be discussed here. I will say that the BF would probably be OK, and operating voltage with only 50K max on the gate is certainly a different condition from 5G, or about 100,000 times different. ;-) Therefore, some care is still prudent, but not so much as in the microphone case.
Still, I would like to thank Ed Simon for the tip on the Dale resistors. My present employer found a cost effective Dale resistor that is completely non-magnetic, that works just great. In our reality, these questions are as serious as what topology to use.
John, I don't want to discuss sonic reasons here, I only want to mention that music - here the music as amplified signal - is really the dynamic condition
I will try out the BF but I my feeling tells me that the SK170 is the JFet for my circuit ...
What Dales you have in mind and what about the Caddock 132?
Joao, it is still important to CASCODE the input part, if you have more than 10V on the BF862. The 2SK170 is a very good part for audio inputs, and I use them for just about everything that I make, including phono stages, line stages and power amp inputs. Their capacitance is not low, but their transconductance is good enough and their noise is reasonably consistent. They also have a complement. Usually, I operate the 2SK170 from 10-15V in order to get the lowest and most linear range of the non-linear input capacitance, but this would be BAD for a BF862. Anything above about 7.5V gets scary, as does above 18V for the 2SK170.
Currently I don't use the cascode even with the SK170 but I have to experiment with it as well and compare the circuits.
Can I contact you by PM for some questions out of topic?
Old 29th October 2010, 04:47 PM   #6409
john curl's Avatar
Joao, I think that I understand what you want, but I cannot answer your questions here, because of the 'extra commentary' that almost always comes from people who do not think that questions like these are 'important'. Of course, you can PM me on specific issues. In truth, I have never found any 'dynamic' differences in fets. Resistors perhaps.
However, it is still almost impossible for me to say something about them here, except FACTS. For the record I have used Caddock power resistors and I like them. We have found a particular version of the Dale resistor to be pretty good, but I don't know its exact number. All that I was told is that it is non-magnetic. This is usually a very good thing, but not always necessary. For example, the end caps on the Roderstein Resista resistors have a slight magnetic attraction, probably nickel plating on the end caps, and it doesn't make much difference, in fact, they are a very good resistor at any price. Unfortunately, they don't make them anymore, and that is why we are switching to Dale for our less critical resistors.
Getting back to jfets, it is important to take care about voltage and leakage issues, especially at very high impedances, because then. a carbon resistor just might show its 'excess' noise due to the voltage drop generated across it by the current needed to supply the 'leaking' jfet.
Old 29th October 2010, 06:21 PM   #6410
fireworks is offline fireworks  Switzerland
In several places on this forum people have said that the parallel regulators are superior to the series regulators for high quality audio reproduction power supplies.
Is that so and if yes, then why (everyone's opinion is welcome) ?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
