The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 1st August 2009, 05:41 PM   #581
john curl is offline john curl  United States
john curl's Avatar
Sorry Jan, NOW my scanner won't come online. I could send them in the USA by FAX to someone who can post them.
"Condemnation without Examination is Prejudice"
Old 1st August 2009, 08:53 PM   #582
stinius is offline stinius
Iím just thinking loud here.
All of us know that in music there is nothing such a thing as a constant sine wave, both amplitude and frequency is changing. So why do we measure amps using constant values, fixed frequencies and amplitude?
What Iím thinking about is doing a multi tone test where the pitch of the sin waves is changing. (Just as an example a Ĺ, ľ, 1/8 or 1/16 tone pitch change in letís say 10 periods)
As an example we could use 20, 40, 80 200, 400, 800, 2k, 4k, 8k and 20k Hz.
Well itís just an idea of how to measure the ďmusicalityĒ of an amp.
Cheers.
Old 1st August 2009, 08:53 PM   #583
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I was out to visit relatives, found the circuit. It's now here:
http://www.linearaudio.nl/Miscellaneous/jc.JPG
Measurements are here:
http://www.linearaudio.nl/Miscellane...0meas%202.jpeg
and here:
http://www.linearaudio.nl/Miscellaneous/meas%20ckt_.jpg
jd
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 1st August 2009, 08:55 PM   #584
jan.didden's Avatar
Cheers.
Hint: Look up 'multitone testing'.
jd
Old 1st August 2009, 09:01 PM   #585
jd
Hint: read the post one more time.
S
Old 1st August 2009, 09:07 PM   #586
john curl's Avatar
Thanks Jan. This is only an example circuit circulated among engineers working on the same project. Not for direct application.
Old 1st August 2009, 09:33 PM   #587
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
It's pretty clear what stinius is proposing, it's a variant on multi-tone testing. One problem is sorting out the results using FFT techniques. Sliding tones might fill in everywhere and analog detection of the content in all the spaces might be prohibitive anyway.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 1st August 2009, 11:22 PM   #588
Bob Cordell is offline Bob Cordell  United States
and here:
jd
Thanks John and Jan for putting these up.
The basic way in which the LT1166 is being used here is correct. The signal is not passing through the LT1166, but rather the LT1166 is being used as a shunt dynamic bias spreader.
There are a couple of questions on this information (these are not criticisms).
In the schematic, it does not appear that there is any feedback compensation. Is it supposed to be this way, or is the schematic incomplete in this regard. The way that feedback compensation is done when the LT1166 is used this way has a very big influence on the performance achieved.
In the performance plots, it looks like the LT1166 design is on the left and the conventional design with conventional bias spreader is on the right. Is this correct?
It looks like the top plots are THD spectra while the bottom ones are SMPTE IM residuals. Is that correct?
The notations seem to suggest that the magnitudes of the distortions are less witht the 1166, but with more high-order content. Is that correct? This pertains to interpreting the scale factors.
Thanks,
Bob
Old 2nd August 2009, 01:16 AM   #589
syn08 is offline syn08  Canada
To start with, slap a 1uF (or more) film cap across pins 1 and 4 and everything will be one order of magnitude better. Depending on the measurement results, further refinements may or may not be required.
Old 2nd August 2009, 01:31 AM   #590
KSTR is offline KSTR  Germany
KSTR's Avatar
Doesn't that defeat the whole idea of the dynamic shunt regulator action? At least for higher frequencies?
- Klaus
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
