The Lounge A place to talk about almost anything but politics and religion.
Old 27th August 2010, 04:26 AM   #5881
KBK is offline KBK  Canada
At one time in this thread or the previous incarnation of it, I mentioned that Dave Reich of Classe used to measure off his solder so that each solder joint had precisely the same amount of solder in it.
Look at the images in this thread. Yes..it appears he did indeed do that exact thing.
pre amp balance
The only real reason in my mind, that I can think of, is that he heard a difference, if it was not exactly so.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 27th August 2010, 04:40 AM   #5882
Originally Posted by Joachim Gerhard View Post
Aliasing dirt sounds no good so it has to be removed even at the expense of bandwidth reduction.
Inter-channel capacity for micro level phase differential (or timing/temporal) is all that really counts and even a 15khz rolled off stereo tube amp can achieve nearly light-speed freqs in that respect. It can split hairs better than any digital recording system in existence or on any drawing board.
Old 27th August 2010, 01:49 PM   #5883
Jacques Merde is offline Jacques Merde  United States
Jacques Merde's Avatar
Originally Posted by 1audio View Post
The potential of the Sony tuner is great as a source if its output analog limitations can be overcome. The real disappointment is the lack of a digital output since the internal processing is all digital.
That's an interesting idea. Has anybody considered what it would take to splice a AES/EBU and/or S/PDIF transmitter in place of the DAC?
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 27th August 2010, 03:14 PM   #5884
bear is offline bear
expert in tautology
bear's Avatar
I like the hat and the outfit... the chair is not bad either...
wonder how he pays for his needs and things like transportation?? The hat seems warm...
Obviously no hi-fi system for him
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 27th August 2010, 05:59 PM   #5885
Johnloudb is offline Johnloudb  United States
Johnloudb's Avatar
_-_-bear
My Website: Hyperacusis, Tinnitus, My Story
Old 27th August 2010, 08:24 PM   #5886
1audio is offline 1audio  United States
Schematic for the FM tuner is here Sony XDR-F1HD Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
There is an I2S output from the chipset but its unclear at first glance if it can be used directly. Pins 15,15 and 17 of IDM1 are the signals in question.
Demian Martin
Product Design Services
Old 27th August 2010, 08:36 PM   #5887
john curl is offline john curl  United States
john curl's Avatar
That might be an option for some. I would just be happy with a better filtered and non-ceramic cap output stage. At this stage, without improvement, the tuner has limited interest, subjectively, and I tend to ignore it, even when it is in my system.
"Condemnation without Examination is Prejudice"
Old 27th August 2010, 09:53 PM   #5888
Johnloudb's Avatar
I think pin 25 of the TUX-DSP01 labeled I2S_Out would be where you'd take the digital output. Is that right? It's not connected to anything.
Will my Benchmark read the digital I2S format at it's coax digital input? Or does it need to be converted to S/PDIF format?
I would be interested in adding a digital output to this, if it's not too involved. but I'm still going to do the analog output mod too, and see how that sounds.
Old 27th August 2010, 09:56 PM   #5889
Johnloudb's Avatar
Opps, I meant pin 24.
Old 27th August 2010, 10:37 PM   #5890
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I2S has usually the left and right channels seperate and a seperate clock so it has three independent signals. I am really surprised that a tuner has an output like that.
S/PDIF has all three signals in one chain of inforamtion so i think it is not directly compatible.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
