The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 5th August 2010, 01:48 AM   #5461
john curl is offline john curl  United States
john curl's Avatar
Anyone else who has worked with Vu meters.
"Condemnation without Examination is Prejudice"
Old 5th August 2010, 02:44 AM   #5462
johnferrier is offline johnferrier  United States
johnferrier's Avatar
I use SPL meters in an attempt to set playback levels to record levels. As I understand them, VU meters measure decibels of the electrical signals (post electro-mechanical transducer in the case of recording, and pre, in the case of playback). VU meters are an aid to adjust record levels to prevent clipping (distortion).
Using time-averaged levels, I'd like to find a means to correlate VU readings (or the like) to SPL readings. Of course, transducer response and room acoustics are large factors.
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 5th August 2010, 03:00 AM   #5463
The Blowtorch does not have a power switch to avoid using signal switch/relay contacts for power on mute?
Old 5th August 2010, 03:46 AM   #5464
Melon Head is offline Melon Head  Australia
Banned
Hi John
I think I understand what you are implying here with your your Vu meter analogy and I agree with it entirely based on what I read at the TNT website.
However I have some experience with dither that is used in controlling servo-hydraulic machines for fatigue testing of materials. In this application it has the complete opposite effect. I wish I knew (it looks like I have something to read about now) exactly what the dither is doing to improve the response of the machine so I could comment further. However I could probably post some pictures to demonstrate how it improves the response. I don't know if this could be applied to audio in the same way it used in the servo hydraulic machine, but if it can, it definitely is worth looking into.
Old 5th August 2010, 05:12 AM   #5465
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by thanh1973 View Post
Hi John
What VU meter analogy was that? I don't see where John made any sort of analogy to a VU meter.
I made an impromptu "cognitive dissonance" meter in response to one of SY's posts and then John asked if anyone had ever seen or used a VU meter.
Where exactly was the analogy?
se
The Audio Guild
Old 5th August 2010, 05:38 AM   #5466
Banned
I read his mind. He hasn't shared the analogy yet.
I could be way off track with what he is trying to say here.
Old 5th August 2010, 05:42 AM   #5467
john curl's Avatar
Well, I noted that a continuous +3 on a Vu meter shows somebody not knowing how to make a proper recording. It looked silly to me, even though it meant something else. Nothing really hidden or that important.
Old 5th August 2010, 05:52 AM   #5468
Steve Eddy's Avatar
I haven't seen any evidence that he's trying to say anything with regard to VU meters.
What TNT article are you referring to?
se
The Audio Guild
Old 5th August 2010, 08:15 AM   #5469
Banned
Dither article
That Dither Thing - [English]
Yes it works well if the intended signal is a sine wave.
What if the intended signal was a stepped sine wave as pictured would it still smooth the signal to a sine wave
Old 5th August 2010, 08:28 AM   #5470
Werner is offline Werner  Europe
It works with her voice, too.
I can testify that said voice, while sinuous, is not a sine.
ceterum censeo MQAm delendam esse
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
