John Curl's Blowtorch preamplifier part II John Curl's Blowtorch preamplifier part II - Page 540 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 3rd August 2010, 09:53 AM   #5391
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Johnloudb View Post
Yes, the subconscious is a wonderful thing and the conscious mind can only focus on one thing at a time. From what I read, and I didn't read it word for word, they were measuring stress. They took a lot of effort to make the participants comfortable.
And like I said before, if the results are consistent and repeatable then it's a good indication that they heard the high frequency. They did it backwards and forwards, double blind, Jan.
When I spend a long periods (days) listening to only SACDs and LPs I have a difficult time going back to CDs, even very good recordings. It takes my ears time to adjust. I find them more fatiguing for whatever reason.
Surely you saw the pictures Jan.
I'm certainly no expert in reading PETs or EEGs but it sounded like they knew what they were doing.
John
Yes I think you and Jakob are right. They seem to have found a link between that HF presence and audible perception, not just brain activity. Well. What do we do now?
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 3rd August 2010, 11:22 AM   #5392
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by simon7000 View Post
some things
True, the walls of soundproofed rooms in the late 70s sorta looked like the ones individuals in a straightjacket monitor.
In later years, a sound and vibration professor taught me that they're not supposed to look like that.
(this guy : http://www.shipstructure.org/pdf/78symp08.pdf)
On a good day, i can still hear the scratching sound of spider's feet walking across a table, from close distance.
Likely the reason why i keep spending silly amounts of money on silly audio gear.
Makes as much sense as staring blind at 2000dB per octave formulae. :-)
Old 3rd August 2010, 01:35 PM   #5393
jan.didden's Avatar
Originally Posted by john curl View Post
[snip]
What is directing me to talk about this is the fact that an engineer friend of mine is giving a paper or two at the next AES. He has done his homework and measurements, but I told him last night, to not necessarily expect that he will get into the JAES. If things are what they have been over the last decades, he will be rejected. Still, it is about time that his work sees the light of day.
Of course, he is only an engineering graduate from UCB, worked at AMPEX, Sony, and many other companies and has a number of patents. Still, I have concerns.
I think that I can predict the result if I knew the subject.
jd
Old 3rd August 2010, 02:16 PM   #5394
Johnloudb is offline Johnloudb  United States
Johnloudb's Avatar
Originally Posted by nicoch46 View Post
HI
well now I feel good, but last year my hyperacusis like a lot my turntable and not the 1541 nos or walkman , cd ,pc mp3
the TT give me the only way to ear my music....
Glad you're feeling better!
Yes, you could be right about that, but we don't really know since they didn't test the subjects hearing from what I read, unless I missed something.
Another interesting fact is that people with hyperacusis often can hear in the negative decibels on a hearing test. They often hear in the down to -7dB or below. So people can hear sounds they're more sensitive to, better.
John
My Website: Hyperacusis, Tinnitus, My Story
Old 3rd August 2010, 02:38 PM   #5395
simon7000 is offline simon7000  United States
John
Actually it is considered normal to hear -7 at midrange frequencies! This has been incorporated in a few standards!
Old 3rd August 2010, 04:41 PM   #5396
Johnloudb's Avatar
Thanks, I wasn't aware of that. But not many people can hear that quiet, if you trust the audiologists, and ENT's I've talked with. It usually varies between 0dB and +15 for normal hearing. What about -17dB? Well, that's what one person claimed she was tested for. Don't know how accurate that was.
I know my ability to hear quiet sounds improved in a hearing test when my sound sensitivity got worse. Hearing in the -dB range is typical of people with hyperacusis, unless they have hearing loss.
Old 3rd August 2010, 04:46 PM   #5397
Blues is offline Blues  United States
Blues's Avatar
Originally Posted by jacco vermeulen View Post
...(this guy : http://www.shipstructure.org/pdf/78symp08.pdf)
So your amps described as "Built like a battleship" still does vibrate along with your battleship loudspeakers?
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 3rd August 2010, 05:13 PM   #5398
Johnloudb's Avatar
Simon, I just brought that up because people have a natural dislike for some sounds that the brain turns up the gain for. I think I can say these sounds often exist is reproduced music. Could be that we can hear these sounds at even lower levels than we can hear other sounds.
Sounds you dislike are annoying. But, some sounds our ears are naturally phobic to, as well. Sounds you're phobic to can hurt your ears, and a sound my ears were naturally phobic to is what initially caused my hyperacusis.
This is all theory, but it's a theory works very well in treating hyperacusis, phonophobia (fear of sounds), misophonia (dislike of sounds).
Old 3rd August 2010, 06:03 PM   #5399
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
>Or girlie guys. ;-)
Or girlie girls ;-)
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 3rd August 2010, 06:03 PM   #5400
john curl is online now john curl  United States
john curl's Avatar
Well, I'm glad that some here can hear more than MP3 or even CD. I thought it was 'proven' by jj and everyone else in academia that everything else was a waste of useful bandwidth. ;-)
I feel that it is not so much 'why' we hear, but what we hear, at least those of us who can hear differences in audio equipment.
Of course, we can be fooled, or mistaken at times, but so what? Do we have to reject everything, just to minimize some possible mistake?
"Condemnation without Examination is Prejudice"
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
