The Lounge A place to talk about almost anything but politics and religion.
Old 26th July 2010, 01:08 PM   #5221
On Hiatus
SY's Avatar
Procrustes rolls out his bed, right on schedule.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th July 2010, 01:12 PM   #5222
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Jakob2 View Post
@ janneman,
we should avoid to use (d)blind as a synonym for a ´good´ test.
´Blind´ or ´double blind´ is only a certain part of the test protocol, but is in no way sufficient.
Maybe we could introduce something like ´real´ test or ´o.r.v.´ test .
True. How about 'controlled test' versus 'uncontrolled test'?
jd
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 26th July 2010, 01:17 PM   #5223
jan.didden's Avatar
For some reason, this time, I think I get your point.
jd
Old 26th July 2010, 01:21 PM   #5224
Jakob2 is offline Jakob2  Germany
jd
Seems to be the same problem with ´controlled´ .
Maybe orv (for o bjective, r eliable, v alid ) ?
@ SY,
you should consult Athena in all of her virtues from time to time.
Old 26th July 2010, 01:21 PM   #5225
bear is offline bear
expert in tautology
bear's Avatar
Folks, our car is "off the road on the shoulder..." Let's all recall that the discussion ought to relate somehow back to the topic...
I do not think that we are going to wring out the final drop of insight regarding the good or bad of a "DBT" (ABX or not)... not any time soon.
Suggest we move on...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 26th July 2010, 02:05 PM   #5226
jan.didden's Avatar
Maybe orv (for o bjective, r eliable, v alid ) ? [snip]
OTOH, 'controlled' clearly shows the intention of the test. ORV does also, but I doubt that that will catch on widely.
jd
Old 26th July 2010, 02:51 PM   #5227
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
You are right bear. What will come out of that test will be that all competently designed
electronics sound the same. So let´s make our products cheaper and smaller as Peter Walker was sugesting.
Old 26th July 2010, 03:34 PM   #5228
@ janneman,
´controlled´ is necessary but not sufficient while ´orv´ is comprehensive.
Of course, you´re right ´orv´ will most likely not suceed.
Maybe something like ´competent´ or ´qualified´ could serve.
An objective, reliable and valid test would most probably bring a positive result (rejection of the null hypothesis) if a difference is audible (at least to one listener on earth)
Old 26th July 2010, 04:29 PM   #5229
johnferrier is offline johnferrier  United States
johnferrier's Avatar
_-_-bear
Can someone recommend specific source components that are best with a Blowtorch?
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 26th July 2010, 04:33 PM   #5230
PMA is offline PMA  Europe
PMA's Avatar
You would appreciate an original BOM, I would guess
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
