The Lounge A place to talk about almost anything but politics and religion.
Old 26th July 2009, 11:55 PM   #511
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
...Fourth approach exists that I use, you don't: an asymmetrical class A amp, with a source follower powered by one more bootstrapping source follower, and loaded on a counter-modulated current source. In such case power variations will be minimal due to phase shifts between voltage and current when loaded on a real world speaker.
The Devil is not so terrible as his math model is!
Old 27th July 2009, 12:17 AM   #512
1audio is offline 1audio  United States
The concern I expressed above is that the time constant at the sensitive junction for the temperature shift can be near the audio range or at least the range of modulation of audio tones (attack and decay of a note). Even if the heatsink is infinite the resistance to it is not zero and the can be a short term chnage in the devices. Thgis is well understood in IC's and efforts are made to control the modulation of sensitive parts by output devices. However the issue may still be significant in an amp. Is there a way to measure it? Perhaps a change in a low level HF tone while a large change at nearly DC is applied?
Demian Martin
Product Design Services
Old 27th July 2009, 12:30 AM   #513
KSTR is offline KSTR  Germany
KSTR's Avatar
Sounds like a good idea. Something like measuring small signal HF Zout during/after a power burst, by backdriving the amp with a LF current. Maybe in a high (noise) gain config to make it more readily apparent.
- Klaus
Old 27th July 2009, 12:57 AM   #514
Wavebourn's Avatar
This good idea was implemented thirty years ago, about month ago I described it in details on this forum. I used a complex HPF to separate a high tone from a low disturbing one so it won't swing a high pitch tone from an oscilloscope screen. The problem was, first filters I used had non-linear cores so could not be trusted.
Old 27th July 2009, 01:44 AM   #515
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally posted by stinius
Attached is an example of a slightly better model.
BTW: the thing I showed was not made by SPICE, but by COMSOL
OT: I really hate the limitations in file size that is allowed to attach.
Another issue is that the self heating time constants on the die are orders of magnitude smaller than the heatsink/ambient ones. As an aside Intel is working on thinning wafers to 10 microns to get the heat out (18" wafers BTW ) . Mind-boggling (18" wafers that is).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 27th July 2009, 01:53 AM   #516
KSTR's Avatar
Was that really a Zout measurement, Anatoliy?
Old 27th July 2009, 02:10 AM   #517
Wavebourn's Avatar
No Klaus, it was made for observations of linearity change with voltage swing, I used it to experiment with everything in the amp to see how different changes of topology and regimes were reflected on linearity. I never measured THD, I always used to observe waveforms and to listen to sounds the same time. It was more revealing and useful, like giving thermometers to each and every patient VS averaging of a temperature in the clinic for some kind of a report.
Old 27th July 2009, 02:58 AM   #518
I think the most interesting to me right now would be the transient phase change to the HF signal. I'm not sure how the filter will effectively isolate to tone or if having the filter will cause an effect in the process. Making a good isolation filter that won't distort the tone is the hard part.
Demian Martin
Old 27th July 2009, 03:10 AM   #519
Wavebourn's Avatar
I have a pair of LMI-500 filters by UTC, I can bring them when I come.
Edit: I've found they are LPF actually, 60 dB/Oct, so the task is reversed: like 200 Hz to observe, 20 KHz to disturb. Not so good for phase angle observations, but who knows...
Old 27th July 2009, 09:22 AM   #520
cliffforrest is offline cliffforrest  United Kingdom
Wow! That will be like a rice-paper frisbee
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
