The Lounge A place to talk about almost anything but politics and religion.
Old 6th July 2010, 03:06 PM   #4871
john curl is online now john curl  United States
john curl's Avatar
EUVL, there is no need for an input coupling cap with jfets on the front end. A moving coil cartridge cannot produce DC, and the leakage of the jfets is very low. SOME bipolar transistor circuits could create significant bias current with potentially problematic results, but not always. The Levinson JC-1, for example, provided bias cancellation to a first order, and we had no complaints about biasing current problems.
"Condemnation without Examination is Prejudice"
Old 6th July 2010, 03:42 PM   #4872
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Originally Posted by Rod Coleman View Post
Constructors wondering about assembling matched JFETs into a long-thermal time constant module may enjoy Jim William's application note AN124 at LT. He shows a pair of K369s epoxy-moulded into the cap of an apple-juice bottle, in a note aimed at measuring sub-uV noise levels in voltage references. The general construction techniques Jim uses are, as usual, works for admiration.
http://cds.linear.com/docs/Applicati...ote/an124f.pdf
It's always nice to wade through all the subtle stuff but in the end floating a low noise preamp & A to D on the reference and doing all the signal processing in the digital domain would get the job done. Quantec had an excess noise fixture (noise on top of a 10V DC) that used ordinary off the shelf components.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 6th July 2010, 07:50 PM   #4873
john curl's Avatar
One colleague of mine, who uses 2SK389's for a very low noise front end, uses 2 pairs of these devices with the same DC offset, and then mates them face-to-face for virtually 0 offset. He then adds thermal shielding to keep any change in temperature from effecting the readings to below perhaps 100 seconds or better.
Old 6th July 2010, 07:56 PM   #4874
cliffforrest is offline cliffforrest  United Kingdom
"He singeth a quiet song"
Brilliant! I love him!
H&H and Jim's book jostled for shelf space ...
Old 8th July 2010, 01:58 PM   #4875
simon7000 is offline simon7000  United States
Scott,
Nice to see you again.
So now that I have to buy 64 bit computers, does that mean we will soon be getting 64 bit a/d's and d/a's?
I can only imagine how good they will sound!
ES
Old 10th July 2010, 03:34 PM   #4876
johnferrier is offline johnferrier  United States
johnferrier's Avatar
The Blowtorch as a preamp is 130 watts . . . really?!?
"the unit draws over 300W on turnon and then a steady 130W in use"
A headphone out would be another 130 watts? And another 100 lbs??? lol
Old 10th July 2010, 04:57 PM   #4877
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Less than 30W continuous, which is plenty already, considering the absence of volume/source switching current.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 14th July 2010, 02:53 PM   #4878
Originally Posted by simon7000 View Post
Scott,
I can only imagine how good they will sound! ES
Sorry Scott,
I thought I gave you a nice straight line. But for those who didn't get the joke at 64 bits you can go from the thermal noise level of a 150 ohm resistor at room temp to the energy required to remove the atmospheres of all the planets in the solar system and still have some oomph left!
ES
Old 14th July 2010, 06:20 PM   #4879
john curl's Avatar
Well, back to the real world. The Blowtorch preamp is like an expensive automobile. If you can't afford the electricity, don't buy it. Why does it take so much current for a 'simple' preamplifier stage? This is because we want the amplification to be as effortless as possible, just like a high torque engine in responding to a change in conditions.
A secondary factor, especially for the phono stage, when included, is for lowest noise from the paralleled jfets on the input.
Old 14th July 2010, 07:19 PM   #4880
Sorry Scott,
ES
I've been away a lot lately. I don't remember who, but one of the great tape recording gurus (Doug Sax or Keith Johnson) once said in print that it would probably take 256 bits to equal their tweeked 30ips recorders.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
