The Lounge A place to talk about almost anything but politics and religion.
Old 24th February 2014, 11:20 AM   #48531
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by jacco vermeulen View Post
Sst, it's how I recondition light bulbs.
Please send me the test-recovery file data in *.wav, I'd like to try it as well.
Old 24th February 2014, 11:44 AM   #48532
gk7 is offline gk7
Originally Posted by VladimirK View Post
Everybody who did it reported "wow".
For an even increased "wow" effect try whiskey "burned in" for 20 years or so...
Old 24th February 2014, 12:16 PM   #48533
VladimirK is offline VladimirK  Uzbekistan
Yes, this is also not a bad practice, sometimes, with good armagnac (for me). And one could also try white-noise signal burning-in, if square wave is dangerous. It would be wise to make this simple procedure first, before developing joking.
Old 24th February 2014, 12:59 PM   #48534
a.wayne is offline a.wayne  United States
Sin Bin
I usually let a green amp run for 48 hrs before listening , interesting you run @ 80% for 24hrs I do agree break in is needed and essential on everything , annealing is suggested , what about compaction ..?
@Sy,
Are you serious about reversing procedure ...? If so then Wire direction after break in is very important ...
Old 24th February 2014, 02:09 PM   #48535
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
In my servicing career, I have observed an interesting initial burn in' effect, many times.
One of my amplifier standard servicing procedures (particularly for PA amplifiers) is to blanket resolder the power supply and output stages....this helps to ensure long term reliability, and reveals sub optimal solder joints that on first inspection would seem to be ok.
So, after this rework, my procedure is to power up via lamp and variac whilst checking DC conditions.
If all is good, I then reconnect to standard wall power, and allow thermal conditions to stabilise (lid on), whilst periodically checking and adjusting bias currents as required.
Usually, I will allow this no signal process to progress over four or more hours.
The next step is to audition the amp with known source, known programme material, and known speakers....ie my quite good quality reference bench system.
Initially listening is at low volume/power for extended period.
Then, I gradually raise the volume and listen closely.
The curious thing with fully reworked amplifiers that I have found repeatedly, is that at low levels, initially the sound is 'wrong', badly 'wrong' and this distortion gets worse as the volume is slowly raised, and reduces as the volume is decreased.
When a threshold is reached (first clip events ?), the amplifier/sound suddenly and dramatically changes for the better, and remains so, even after repeated volume changes, power up/down cycles, or fully cold restart.
This once only effect is perhaps not as stark as I have described, however a trained ear alerted to this behaviour will discern the sonic changes.
I expect that the likely explanation is that ferrous materials get demagnetised during the soldering process, and gentle clipping sets a magnetisation level in DC current path ferrous containing components.
Greater minds may have a proper explanation.
Dan.
Old 24th February 2014, 02:26 PM   #48536
john curl is offline john curl  United States
john curl's Avatar
Vlad, decades ago, my associates built a 'break-in box' with an approximately 700Hz square wave. We found it satisfactory also, and easier on the amp. Your explanation of WHY 'break-in' works is what we believe to be true also. I have even offered 'evidence' here, but to no avail.
"Condemnation without Examination is Prejudice"
Old 24th February 2014, 02:44 PM   #48537
Originally Posted by john curl View Post
......I have even offered 'evidence' here, but to no avail.
Hello John, do you mind give your findings again.
Dan.
Old 24th February 2014, 02:46 PM   #48538
john curl's Avatar
I'm tempted.
Old 24th February 2014, 02:51 PM   #48539
jcx is offline jcx  United States
it is just too suspicious that "burn in" is Always an Audible Improvement
not likely if it were objective materials property changes causing real electrical circuit performance changes - at least some changes could be expected to go the "wrong" way, stablize at a less optimal state after burn in
Old 24th February 2014, 03:11 PM   #48540
jneutron is offline jneutron  United States
jneutron's Avatar
Odd that you choose to bracket the word evidence as..... 'evidence'.
It appears you also question the validity of it. edit: (scientific validity)
jn
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
