John Curl's Blowtorch preamplifier part II John Curl's Blowtorch preamplifier part II - Page 47 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 24th July 2009, 06:10 AM   #461
PMA is offline PMA  Europe
PMA's Avatar
OK, I made a brief simulation on push-pull class A dissipation. I used some real circuit to make it quick. This is a primary school of power amplifiers. Power (red) is for 2 different output amplitudes. Blue is a current (idle of some 1.6A) thru one output device for two different output voltage amplitudes.
Old 24th July 2009, 06:25 AM   #462
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Pavel, it is valid for a push-pull stage biased in class A, but not valid for a stage designed for class A, like in my Tower amps.
As soon as I designed it and proved the concept, the rule of thumb is no more valid. It is not a problem anymore, at least it is not unavoidable problem.
The Devil is not so terrible as his math model is!
Old 24th July 2009, 06:31 AM   #463
PMA's Avatar
Anatoliy, that's why I emphasized the push-pull both in text and the image.
Old 24th July 2009, 06:43 AM   #464
Magura is offline Magura  Denmark
Magura's Avatar
Chris:
You're making a good point, often overlooked by engineers.
The effect of this issue, is often causing issues in both electrical and mechanical engineering.
One of the main reasons that the "calculations is the only way" attitude seems to cause problems, is that often tolerances are not taken into account in the equation, as it would make the equation quite complex.
Safety factors are relatively easy to feed into an equation, but when you have a tolerance in both ends of the scale, so to speak, it's all of a sudden a quite different ballgame.
I see the result of this quite often in my everyday job.
Either tolerances were not summed up, or over engineering, making the final device malfunction.
So much for simplified equations.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 24th July 2009, 06:48 AM   #465
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Nice to see the freq doubling confirmed
Quiz: what is the relationship between load resistance, bias current and supply voltage to make the dissipation curve linear? Is there such a condition? Hint: if Iout doubles, but Vce halves, dissipation remains constant.
(A simplified equation will do). Any engineers out there?
I'd do it myself but I need to go to a Masterclass Tube Design . Really!
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 24th July 2009, 06:54 AM   #466
PMA's Avatar
Quite difficult task to force the power to get negative
Old 24th July 2009, 07:29 AM   #467
Wavebourn's Avatar
AD8052 looks interesting, though +/-5V only...
Old 24th July 2009, 09:31 AM   #468
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
I noted by
http://www.diyaudio.com/forums/showt...&pagenumber=15
that many "death links" are to find, e. g. from Richard Perez (Justcallmedad). Also about http://www.archive.org/web/web.php I don't get this one.
Old 24th July 2009, 11:26 AM   #469
stinius is offline stinius
This is for Push-Pull Class B.
I had to split the document; the file size was too large.
Old 24th July 2009, 11:29 AM   #470
Page 4
I had to reduce the size of this page so the images are not easy to see.
I can post them separately if there is any interest.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
