The Lounge A place to talk about almost anything but politics and religion.
Old 2nd June 2010, 04:54 PM   #4511
john curl is offline john curl  United States
john curl's Avatar
I was referring to the original Dyna phono stage and the corresponding Audible Illusions 6DJ8 version of essentially the same circuit.
"Condemnation without Examination is Prejudice"
Old 2nd June 2010, 09:36 PM   #4512
john curl's Avatar
I would like to make the comment that vacuum tubes, while very good, are not what I design with. The 12AX7 has been very successful over the decades, BUT it is limited, especially in current drive, which can be VERY important in some situations.
Let us go on about solid state solutions, and leave the tubes to another thread.
Old 2nd June 2010, 09:59 PM   #4513
On Hiatus
SY's Avatar
Boooooo! Booooooooooo!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd June 2010, 12:45 AM   #4514
john curl's Avatar
Please stick with your own threads, SY. There are plenty of threads for discussing vacuum tube solutions. However, threads concerning solid state solutions at a professional level are relatively few.
Old 3rd June 2010, 01:17 AM   #4515
On Hiatus
SY's Avatar
My apologies. I thought you were interested in high performance design, not just restricting yourself to familiar and comfortable solutions. You're certainly welcome to continue discussing cheaper and easier compromises without me interfering.
Old 3rd June 2010, 01:53 AM   #4516
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Silicon circuits, even with the latest generation of OPamps can be made to sound extremely well. When it comes to measurements it is hard to make a tube stage that has as low distortion, noise and very high bandwidth. Using discrete circuits with relatively high voltage it gets quite thin for tubes. I can see no cheap and easy compromises provided the circuit is competent and build with good parts. I whould say that it is cheaper and easiers to make a good sounding tube circuit. I know what i am talking about because i had a lot of tube amps at home with aspiration to be "The Best". I listened at length to them and i measured them as good as i could. Except a portion of harmless second harmonic and a different noise profile i could not find any magical properties in them. For me it is just another technological option. A lot what a tube can do sonically can be mimicked with single ended Fet circuit and i got particular good in building buffers that add whatever distortion and noise i like. Actually i think a lot what makes a tube sound good is adding some ( small ) extremely attractive distortion to the music. But now i am back where i should not be here.
Old 3rd June 2010, 02:56 AM   #4517
john curl's Avatar
Joachim, I do not think that any IC op amps do as well as a well designed piece of tube equipment, OR good discrete solid state electronics.
As far as IC's are concerned, today I tried your suggestion of National OP AMP as replacement for the AD797, which is very good, but too expensive, in my opinion, compared to its competition. It works fine, sounds good, and I did not measure anything higher than 3'rd harmonic. Perhaps this IS progress in IC's, I hope so.
My problem with vacuum tubes is the related coupling to and from it, that means lots of caps, and or transformers. It is these components that I worry most about.
Old 3rd June 2010, 03:10 AM   #4518
Allan Wright and i listened in my place to his top Tube Stage compared to one of my OPamp based preamp. Ask him. I do discrete too when i try to make the best posible but this little preamp is a lot of fun. The MC input stage in that Pramp is an INA build from two LME49990 and one ADA4627 per channel. A conventional feedback structure with the LME49990 brings not the best sound out of it. I tryed virtually everything, series feedback, shunt feedback, differential etc. and the INA topology works by far the best soundwise. I can not measure distortion in that circuit at cruising level. It is below the noise.
Old 3rd June 2010, 03:18 AM   #4519
Here come some measurements. This is the resolution floor of my analyser.
Old 3rd June 2010, 03:21 AM   #4520
Here come the measurements from an early prototype that used 2 x AD797 and one OPA827. The new version is better. I can reduce noise by 6dB with paralleling of input opamps but then it gets expensive again so discrete whould be more economical.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
