The Lounge A place to talk about almost anything but politics and religion.
Old 24th June 2013, 07:16 PM   #40641
marce is offline marce  United Kingdom
Wouldn't that requires a filter, a line cord is generally just that a few bits of wire, and if you use power line communications then your mains is already polluted.
Personally, I believe that if a power cord makes a difference you have some major problems with your set up.
Old 24th June 2013, 07:22 PM   #40642
simon7000 is offline simon7000  United States
You can do filtering in a line cord without adding any extra resistance. Harder to do with a mutual inductor.
Old 24th June 2013, 07:31 PM   #40643
tvi is offline tvi  Australia
tvi's Avatar
filtered power cords
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 24th June 2013, 07:32 PM   #40644
qusp is offline qusp  Australia
qusp's Avatar
yes, most of these assertions seem to rely on mentioning levels, or locations of noise that have no bearing, or on the equipment you are using having such stupidly low PSRR that mV of ripple causes 'obvious' noise.
of course some of these things are just going to be ground loops caused by bad setup, combined with unnecessarily high and unused voltage gain
Old 24th June 2013, 09:16 PM   #40645
john curl is offline john curl  United States
john curl's Avatar
My best fixes for line cords are Bybee devices. (no kidding)
"Condemnation without Examination is Prejudice"
Old 24th June 2013, 09:19 PM   #40646
john curl's Avatar
Yes, my STAX Lambda Pro headphone amp is one of the most sensitive components in my system with regards to changes in power cords. Must be those lousy 'subjective' engineers who made it. '-)
Old 24th June 2013, 09:23 PM   #40647
qusp's Avatar
here we go again ... attention seeking again.
yet more sensitive and generally better STAX systems like DIY T2 paired with O2 seem unaffected ...
Old 24th June 2013, 09:24 PM   #40648
john curl's Avatar
The 'truth' hurts sometimes. '-)
Old 24th June 2013, 09:31 PM   #40649
Alexandre is offline Alexandre
The Pass D1 I/V stage deserves a better picture, here it is.
-Alex
Old 24th June 2013, 09:34 PM   #40650
I havenīt built it, but the D1 looks great for a volume control as well.
Maybe throw a few silonex LDRs in parallel there between Vol- and Vol+ ?
-Alex
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
