The Lounge A place to talk about almost anything but politics and religion.
Old 22nd June 2013, 04:38 PM   #40541
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by scott wurcer View Post
How would you corellate the motion to signal error? We have a 3 axis one that runs on 1uA. It's for pacemakers and I joke that it's a "I fell down and can't get up" signal.
So what does the pacemaker software do then? Up the heart rate to help getting up?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 22nd June 2013, 05:23 PM   #40542
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Call 911 ?
(Funny current, nodus sinuatrialis)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 22nd June 2013, 06:27 PM   #40543
jan.didden's Avatar
Old 22nd June 2013, 06:37 PM   #40544
1audio is offline 1audio  United States
Why not connect it to the stylus and a second to the tonearm. The difference would be the output and the second one would have an error component relating to everything from warp to VTA to tracing correction.
Actually, if there were a real market a MEMs stylus-transducer would be the way to do it today.
Demian Martin
Product Design Services
Old 22nd June 2013, 08:09 PM   #40545
qusp is offline qusp  Australia
qusp's Avatar
i'm not sure, I guess there is some correlation though yes? you'll have to excuse me I really dont know much about turntables and the specific mechanical and thermal distortion mechanisms.
I just figured there would be a difference in heat, distortion and possibly tone depending on the friction and vibration; thus relative weight/deflection caused by the bobbing up and down, but for real usefulness there needs to be another reference location.
I have no idea how you would isolate and remove that distortion, as that would correlated and specific to the individual pressing, its wear/deformation and recording though. maybe a digital reference file that was only mixed in when the playback deviated sufficiently from the reference? but then you wouldnt need the accelerometer really.
complex area turntables when you look that closely, covers a lot of disciplines. the query was simply a curiosity, since the conversation was about installing existing features into a different spot, I thought why not think about leveraging other benefits related to that new location, using new, lightweight technology and find some new functionality while you're at it. i'm sure the feedback would have something to say about the deflection, but making something useful out of it ...
ahh Demian's onto it, interesting puzzle.
Old 22nd June 2013, 08:14 PM   #40546
john curl is offline john curl  United States
john curl's Avatar
I have been patient, but nobody seems to talk about issues related to the pursuit to hi end audio, of which the CTC Blowtorch is one example.
I, too, am rather tired of designing preamps, but that is not all there is to reproducing quality audio electronics. And even if power amps can and will be improved over time, there remains a critical 'weak link' audio reproduction. It is not necessarily digital, itself, BUT the interface between converting the output of a first class D-A, to a final audio signal that would go either to a quality preamp or a first class power amp.
This is usually done with IC's, and pretty good IC's at that. However, problems remain.
First, the IC's are often loaded with a difficult load, due to gain reduction requirements.
This makes the IC's put into a less than optimum situation, and I think that this is a real problem. I hope to research this in future.
Of course, I personally have little faith in CD reproduction for useful evaluation, except 'hit and miss' but even DVD and SACD are compromised by these IC's and their loading. My evaluations start with higher bit rate, high bit inputs, just to see what can be done. From my initial evaluations, high quality phono of the same music is still better.
"Condemnation without Examination is Prejudice"
Old 22nd June 2013, 08:57 PM   #40547
qusp's Avatar
John, thats really funny, you interrupted a fairly interesting conversation about the possibility to leverage new technology to improve analogue playback mechanisms, to launch yet another boring, recycled tirade against ICs and digital ...
Do you think thats the most interesting topic in high end audio? you certainly know the ground and material well.
the result of this is possibly provoking yet another round of discrete and analogue versus Ics and digital, cycling around, mimicking a record.
perhaps you dont realise that there were rather analogue mechanisms under discussion? for improving the analogue playback? what new and positive discussion did you hope to provoke with that, that you might find more satisfying?
Old 22nd June 2013, 09:21 PM   #40548
john curl's Avatar
Boring for YOU, not boring for ME!
Old 22nd June 2013, 09:35 PM   #40549
qusp's Avatar
but you didnt provoke any alternative conversation, you simply attacked your fairly incorrect assumption of what the current one was; using the same old somewhat trollish cliches that you periodically fill these pages with.
Old 22nd June 2013, 10:58 PM   #40550
Rick Miller is offline Rick Miller  United States
John, are you talking about I/V converters?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
