The Lounge A place to talk about almost anything but politics and religion.
Old 5th March 2010, 04:30 PM   #3851
godfrey is offline godfrey  South Africa
Originally Posted by john curl View Post
Cost is not so important, minimum number of series relays is important.
Hi John
It is a pity that it is impractical to use two separate pots (for high range and low range). That would allow only one relay contact to be in circuit at a given time. It would also be easier to use with only 2 switch positions.
I understand the difficulty of having special pot/motor combinations custom-built, but would it not be possible to use two completely separate motorized pots?
Regards - Godfrey
Old 5th March 2010, 04:42 PM   #3852
john curl is offline john curl  United States
john curl's Avatar
Too much hassle, and space, I'm afraid.
"Condemnation without Examination is Prejudice"
Old 5th March 2010, 04:43 PM   #3853
Originally Posted by simon7000 View Post
In the case of a 1K pot with an end resistor the resistors should be 988 ohms, 1.91k, 3.75K, 7.39K, 14.3k, 28K and 54.9K.
Hi Simon
The problem with using this kind of approach with a 1k pot is that you end up with about 100 different switch settings.
Just sweeping e.g. from 50k to 60k will involve going through 10 combinations of series resistor. There will be much clattering of relays - not ideal while one is trying to tune by ear!
Cheers - Godfrey
Old 5th March 2010, 08:09 PM   #3854
simon7000 is offline simon7000  United States
Originally Posted by godfrey View Post
Hi Simon
Cheers - Godfrey
Depending on the complexity of the controller more relays can be used to minimize the number of switches being used as shunts. I don't think the miniature relays being used are as noisy as you expect. Inside a solid case or two they should be well below the problem level.
Somewhere around 15 relays will limit you to mostly 2 switches sometime 3.
Old 5th March 2010, 11:09 PM   #3855
On Hiatus
SY's Avatar
Hi Simon
That's why God invented the reed relay.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th March 2010, 11:12 PM   #3856
john curl's Avatar
I am blocked once more, lost another one, that would clarify the situation.
Old 7th March 2010, 05:39 AM   #3857
john curl's Avatar
Well thanks everyone, for your inputs. It might be better to move onward to some other topic that is more general.
Old 7th March 2010, 03:58 PM   #3858
John,
I am still measuring resistors and an interesting artifact has shown up in measuring the Vishay bulk metal film resistors. From my preliminary measurements I would characterize these as being a "Warm" sounding resistor.
Have you or any one else have experience with them?
Old 7th March 2010, 04:12 PM   #3859
john curl's Avatar
Interesting
Old 8th March 2010, 06:32 AM   #3860
john curl's Avatar
Simon, we will probably use naked Vishays for our project. I don't mind using original Roderstein resistors or Corning Grey resistors, either.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
