The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 24th April 2013, 12:01 AM   #38501
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Cascodes? What was the advantage of breaking up middle resistor into 4 resistors plu pot. I can see the pot for adjustment of contribution of each half, but why split the others? I like being the only guy that doesnt know.
...Shape the sound , Man!
Old 24th April 2013, 12:15 AM   #38502
john curl is offline john curl  United States
john curl's Avatar
OK, once again, here is the minimum, and then the more versatile version:
"Condemnation without Examination is Prejudice"
Old 24th April 2013, 12:17 AM   #38503
On Hiatus
SY's Avatar
Originally Posted by buzzforb View Post
Cascodes?
That's one way, but I think that would take more than 4 more parts. I also think there's a better way. Let's see if John has gone there yet.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th April 2013, 12:37 AM   #38504
john curl's Avatar
Of course there is the 'folded cascode version, which I use with Vendetta and the CTC Blowtorch, but it is actually easier to look at this basic (not primitive) version of the 4Q input stage, and learn what each of the resistor sets do. Here, for example, is a more typical approach that I use with Parasound and Constellation.
First the original, second the typical:
Old 24th April 2013, 12:52 AM   #38505
john curl's Avatar
Buzzforb, your questions are revealing.
First, some resistors give feedback, others give bias, some do both. The only obvious resistor function on the input is the variable pot.
It can, acting alone, control the total current of the entire 4 devices, forcing the n channel pair current to match the p channel pair current, due to the fact that there is no ground reference, and the only place for the current in all 4 devices to flow, is with the variable pot, YET the bias pot is not really necessary, just a convenience.
(By the way, I will talk about locally connected cascodes later, SY.)
Old 24th April 2013, 01:06 AM   #38506
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by john curl View Post
I have never heard the device being criticized at this time. I have no opinion of it, at this time.
You're right. I misread what you wrote. My apologies.
se
The Audio Guild
Old 24th April 2013, 01:32 AM   #38507
hitsware is offline hitsware
Old 24th April 2013, 01:44 AM   #38508
buzzforb's Avatar
Here is the 'minimum' version for discussion at the moment:
Does this version contain feedback or is it just another way of loading the output?
Old 24th April 2013, 02:14 AM   #38509
john curl's Avatar
This version uses the 1K 'load' resistors also as feedback resistors.
What is missing is the BIAS resistors. This simple design runs on the Idss of the input devices and there is NO control their current, so extreme selection would be necessary if we used the design this way, BUT it is the most simple way to show it in full 4 Quadrant symmetry.
Old 24th April 2013, 02:52 AM   #38510
john curl's Avatar
Here is the CTC Blowtorch way of input current control:
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
