The Lounge A place to talk about almost anything but politics and religion.
Old 12th April 2013, 08:46 PM   #38001
qusp is offline qusp  Australia
qusp's Avatar
I was talking about the passive preamp John, not the blowtorch
as with many here, I think despite the accompanying rhetoric and somewhat magical claims, which I dont care for, the CTC BT is an impressive discrete preamp and I have never thought any different.
if you must have empty space, leave it empty, dont fill it with an extra 10x as much air-wired signal path as needed. especially when you actually stock the very parts needed to avoid it, but choose not to use them on a single one of the all passive preamps. it wouldnt sell as much wire though. with the erm... shaft extensions installed, the direct out could have 5cm or less wire and max 10cm (easily less) for the transformer coupled out. there is no good reason for it.
Old 12th April 2013, 09:17 PM   #38002
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Even the Blowtorch could have benefited significantly from some shaft extenders.
se
The Audio Guild
Old 12th April 2013, 09:19 PM   #38003
On Hiatus
SY's Avatar
I'm trying really hard to not let out a Beavis and Butthead giggle.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th April 2013, 09:21 PM   #38004
Steve Eddy's Avatar
I'm not trying so hard.
Heh-heh-heh-heh, heh-heh-heh-heh. He said "shaft extender." Heh-heh-heh-heh, heh-heh-heh-heh.
se
The Audio Guild
Old 12th April 2013, 09:56 PM   #38005
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
se
I thought being able to buy one was a shaft extender.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 12th April 2013, 09:58 PM   #38006
john curl is offline john curl  United States
john curl's Avatar
No it would not be practical to use shaft extenders, because IF the customer wanted a balanced input system, then we would run out of room, IF we used shaft extenders. Also, we would have to find an alternate way to securely mount the Shalco switch.
"Condemnation without Examination is Prejudice"
Old 12th April 2013, 10:04 PM   #38007
john curl's Avatar
Now, WHY did I put up someone else's passive line preamp for people to view?
IF the critics here could actually see the GOOD in something, rather than the 'need for improvement' in virtually every case, then we might go forward.
Old 12th April 2013, 10:22 PM   #38008
I have a nice passive preamp, Roderstein resistors and nice Shalco switches it is as transparent as I can tell. The fact that it cost only $250 might degrade it it the minds of some.
Old 12th April 2013, 10:26 PM   #38009
Steve Eddy's Avatar
se
The Audio Guild
Old 12th April 2013, 10:33 PM   #38010
Steve Eddy's Avatar
Why would you be out of room? If you were able to throw all that in with the input selector and volume control at the front of the chassis, why couldn't you put the same stuff in with the input selector and volume control at the back of the chassis and moving the electronics toward the front of the chassis?
Not difficult at all. Especially if you're going so far as to hog your chassis out of solid aluminum billets. Could have actually saved a bit of machining by making two compartments separated by a bulkhead that could have been used for mounting the switch and attenuators.
se
The Audio Guild
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
