The Lounge A place to talk about almost anything but politics and religion.
Old 12th April 2013, 01:30 PM   #37971
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by jan.didden View Post
One gripe I have in general will 'passive preamps' is that they have a largish Zout which opens up de power amp to all kinds of source-impedance-related non-linearities. It's a typical case of isolated thinking, instead of looking at a systems perspective.
OTOH, it's a handy way to demonstrate audible differences between pre- and power amps so in that sense it may actually have an important function in the marketplace.
jan
I thought it was to sell multi-$1000 interconnects.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 12th April 2013, 01:35 PM   #37972
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I was thinking matched pairs of those.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 12th April 2013, 01:50 PM   #37973
simon7000 is offline simon7000  United States
Well,
One of the educational projects around here was to build mic preamps. I let the guys come up with the schematics and I added a few. Built so far is a Langevin from the Cinemag website using their transformers and an inshop built 220 mH inductor and to be fair one from the Jensen website that uses their input transformer and no output transformer, along with a similar design using a Lundahl input transformer and a 5534 as a two stage amplifier. Also constructed a copy of an API from a bad web schematic using a Lundahl 1:2 input transformer and a Triad on the output and then a class A FET design from the web in two versions. One was made with a pot for the gain control and a Triad output transformer, the other used a stepped attenuator and no output transformer, both used a Lundahl input transformer at 1/5.
The listening panel picked the FET version with input and output transformers as the favorite.
Attached is the schematic of the amplifies section.
Old 12th April 2013, 02:04 PM   #37974
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by simon7000 View Post
Well,
If the listening panel is still available, it would be educational too to have the chosen circuit supplied from different PSUs.
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 12th April 2013, 02:33 PM   #37975
George
Yes, that was done with lead acid batteries. On my list is to build a proper power supply. The RCA and Langevin designs assume a poor power supply in their design.
Old 12th April 2013, 02:51 PM   #37976
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
That's how I saw it back in the late 80's when the passives became so popular. So I took the idea of no gain and added an output buffer. It was the basis for Corey Greenberg's Aunt Corey's Homemade Buffered Passive Preamp (Corey never mentioned that in his article, but if you've ever read it, I'm Elvis).
se
The Audio Guild
Old 12th April 2013, 03:06 PM   #37977
bcarso is offline bcarso  United States
diyAudio Member RIP
What were the rail voltages?
Old 12th April 2013, 03:17 PM   #37978
12.8v
Old 12th April 2013, 03:38 PM   #37979
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
SY and Jan
Thinking with the cold side of our brain, we all agree on all these.
But there are two issues .
Tell me one diyer here who settles with an integrated amp he built for more than a few @#!!% months, no matter how much satisfied he is with his creation.
You can not beat overload/recovery characteristics of a passive.
George
George, there is a universum of solutions between a 'passive preamp' and an integrated amp, I'm sure you are aware
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 12th April 2013, 03:42 PM   #37980
jan.didden's Avatar
Originally Posted by PMA View Post
Yes Jan, but 10k stepped attenuator would have <= 2.5k output impedance if driven from low impedance sound source. This is the worst case, and at standard volume it would have something like 50 - 200 ohm. Compare to CTC Blowtorch with its constant 1kohm output impedance, or with tube preamplifiers.
Passive stepped 10k attenuator (like Danish DACT, for example) is the component that affects resulting sound in the smallest possible way. All the active preamps have much more of its own "sound", and the Blowtorch will be no exception.
Interestingly, many here insist on the very, very best, unless someone disagrees with their solution and then 'reasonable' is good enough.
Wish you would make up your minds..
jan
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
