The Lounge A place to talk about almost anything but politics and religion.
Old 26th March 2013, 11:42 AM   #37321
PMA is offline PMA  Europe
PMA's Avatar
Regardless low supply voltage, OPA836 has VERY high noise and VERY low quiescent current. No good for audio, would be source of troubles only.
Old 26th March 2013, 12:03 PM   #37322
fas42 is offline fas42  Australia
Banned
Hmmm, just looked at the AD797 sheet, the OPA836 has 4 times the noise voltage amplitude - does that take it from a winner to a loser?
Frank
Old 26th March 2013, 12:33 PM   #37323
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
High 1/f corners.
But from now on I will be discrete about it.
Old 26th March 2013, 12:46 PM   #37324
Banned
Got it ...
Frank
Old 26th March 2013, 01:06 PM   #37325
Mooly's Avatar
John and Scott (and everyone else). If you had a design brief that said you had to use one of todays dual opamps as a unity gain buffer, what devices might you consider, if the goal was putting sonics above all else. Just one or two examples you might consider worthy to work with from all todays countless offerings.
Also I read that Nelson (probably not alone in this) advocates "throwing away" some open loop gain, either by increasing the noise gain for inverting configurations or (presumably) attenuating and then amplifing for non inverting unity gain. Any thoughts on that ? I think the argument is that many devices run with 100% feedback are right on the ragged edge stability wise.
(I know there are more opamp rolling threads than you can shake a stick at but I'd really value your opinion)
Old 26th March 2013, 01:10 PM   #37326
john curl is offline john curl  United States
john curl's Avatar
I wouldn't use an op amp for that use. I got 'burned' the last time I tried. Nelson is probably right.
"Condemnation without Examination is Prejudice"
Old 26th March 2013, 01:17 PM   #37327
Mooly's Avatar
Fair enough... but if push came to shove and you had to go down the opamp route (lets say no discrete alternative due to board space) what might you use ?
Old 26th March 2013, 01:33 PM   #37328
john curl's Avatar
Please ask someone else, Mooly. I don't have a convenient answer.
Old 26th March 2013, 02:57 PM   #37329
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
No need to shove and I'm not the one for listening tests but a modern JFET dual like AD8066 would do. I don't see the noise as an issue at G = 1. Those are free for me there are more choices out there.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 26th March 2013, 03:33 PM   #37330
godfrey is offline godfrey  South Africa
You can do it like this. For unity gain, just leave out R3.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
