The Lounge A place to talk about almost anything but politics and religion.
Old 19th March 2013, 04:24 PM   #36901
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by Kindhornman View Post
What is it about a sulfur trap that I must have missed along this long tortuous conversation?
I'm guessing something to scavenge sulfur inside the chassis to keep any silver bits from turning black?
se
The Audio Guild
Old 19th March 2013, 04:29 PM   #36902
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by Steve Eddy View Post
We're going with box joints. Here's a preliminary chassis in eastern hard rock maple. Going to use some slipfeathers in the corners of the bottom piece, and there we can use things like bloodwood.
se
Yah, no. I was thinking more like this.
jn
Old 19th March 2013, 04:36 PM   #36903
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
Originally Posted by john curl View Post
I need this sort of exterior fit and finish to compete in the marketplace. I am open to 'serious' suggestions.
its so ugly
Old 19th March 2013, 04:37 PM   #36904
elektroj is offline elektroj  Europe
Originally Posted by Esperado View Post
I consider this kind of pure marketing waste of material and energy, this abuse of resources in a breathless world, as morally unacceptable.
Esperado, do you pull power cords from the wall of all your appliances that draw standby current? Computers? Or drive the most efficient car in the world? Or no car at all? Never listen to tube amps or Class A solid state ones? Still use Pentium I computer, because it still works? Do not hang around in forums for hours and hours to save electricity? Never buy food in plastic packaging? Walk 5 miles instead using transportation? Stick to wind and solar?
".. morally unacceptable" ? A little bit of double standart perhaps?
Old 19th March 2013, 04:37 PM   #36905
This is what inspired my current project. A Gody Model 23 crystal radio from the early 1920's. Wood, Ebonite, Bakelite and brass. Some 90 years hence I still find it a thing of beauty.
se
It's also ugly
Old 19th March 2013, 04:41 PM   #36906
Steve Eddy's Avatar
Much too busy for my tastes.
se
The Audio Guild
Old 19th March 2013, 04:41 PM   #36907
Steve Eddy's Avatar
Originally Posted by QSerraTico_Tico View Post
It's also ugly
To each their own I suppose.
se
The Audio Guild
Old 19th March 2013, 05:15 PM   #36908
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
jneutron,
What is the actual name of that would construction. I am trying to get my head around that joint and how it was constructed? It is a very nice construction and made me think of a Chinese puzzle box.
Old 19th March 2013, 05:25 PM   #36909
john curl is offline john curl  United States
john curl's Avatar
Precision fit is another interesting problem that nobody seems to think much about. Do you know what happens if you make an 'interleaving' case with parts that are a little too long or a little too thick? Or visa-versa? Well, I had REAL EXPERIENCE with NEAL FEAY about 30 years ago with Vendetta Research boxes. Not only with fit, and straightness, but even with where the holes are drilled. In desperation, I even hired a guy to completely go over the design of the box, to make it 'machinist proof' in construction,
to little or no real improvement.
You guys talk big, but you couldn't have done any better, just different. The other absurd suggestion was adding some extra material, JUST FOR FASHION, it itself, being useless as a shield material. What a waste of money! If you want 'art' buy art for its own sake.
"Condemnation without Examination is Prejudice"
Old 19th March 2013, 05:25 PM   #36910
jneutron's Avatar
jneutron,
"Decorative dovetail" was the linked name. I have a book at home on dovetailing joinery, so figured I'd find an example for steve.
If you take the end piece, and do the init dovetail with the maple...then cut off the maple, plane the inner surface flat.
Repeat the procedure on the maple side.
Then do final dovetailing into both for fit.
ps...I don't think the process is amenable to using a router for the second cutting passes. I think the grain of the first insets will be oriented such that the bit will cause tearout as the bit leaves the work. I suspect you'd have to stick with a table saw for the second passes, and leave the joints square. If you want keyed joints, I suspect handsaw is the way to go.
jn
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
