The Lounge A place to talk about almost anything but politics and religion.
Old 5th March 2013, 04:07 PM   #36291
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by gpapag View Post
Thanks Steve.
I don’t qualify even for a “nut”.
Well, as the old Hershey's jingle goes (for their Almond Joy and Mounds candy bars), sometimes you feel like a nut, sometimes you don't.
se
The Audio Guild
Old 5th March 2013, 04:09 PM   #36292
john curl is offline john curl  United States
john curl's Avatar
This design is about 4 times more complex than a single ended input design, and not any quieter.
"Condemnation without Examination is Prejudice"
Old 5th March 2013, 04:10 PM   #36293
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by SY View Post
I If I'm designing a keyboard to actually sell, it's not likely that my remapped version will succeed, even if I can argue that QWERTY is "wrong." The market has a lot of inertia!
Yep, see the Dvorak keyboard. Much better, never widely accepted. Too bad.
Old 5th March 2013, 04:20 PM   #36294
On Hiatus
SY's Avatar
If taken as an isolated block. If you can be sure that there will never be common-mode noise induced at nanovolt levels between the cartridge and the preamp, including pickup of fields by the cartridge, great. Someone who is more concerned with overall system performance might prefer that common mode pickup be rejected.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th March 2013, 04:23 PM   #36295
On Hiatus
SY's Avatar
I tried using one. Massive failure- muscle memory is a tough thing to change. Maybe that's why I rarely use open tunings on my guitar...
Old 5th March 2013, 04:50 PM   #36296
1audio is offline 1audio  United States
Getting decent real world common mode rejection is very difficult. Bill Whitlock has written a lot about the problem. If there is an unbalance in impedance to ground anywhere in the chain the CMRR goes out the window. There is nothing about a transducer that makes its output intrinsically balanced unless it has a center tap. And that will only be true at DC. MC cartridges make it easier, since they are so low Z, to reject voltage fields. But they can be very sensitive to magnetic fields. Optimizing all the pieces to work well together would really require different wiring and connectors from the shell out. The ground reference for the system would be in the headshell. An avid DIYer could make this work but not without a lot of effort. I think most dealers would throw it back at a manufacturer as too much trouble.
Demian Martin
Product Design Services
Old 5th March 2013, 04:58 PM   #36297
On Hiatus
SY's Avatar
That's actually not too far from how I (and several others) have wired our turntables- the "ground" wire connects to the phono preamp chassis and the cartridge is connected via a screened, twisted pair. As I mentioned, the CMR is good enough that I can't seem to induce hum even using extreme measures.
There's a very nice writeup about this in "Valve Amplifiers."
I disagree about the center-tap bit. That can actually degrade CMR.
Old 5th March 2013, 05:01 PM   #36298
PMA is offline PMA  Europe
PMA's Avatar
Joachim has shown more than many circuits.
I saw his latest one (balanced to single ended) here
http://www.diyaudio.com/forums/analo...ml#post3301025
Frankly, not my cup of tea.
Old 5th March 2013, 05:06 PM   #36299
Steve Eddy's Avatar
Not really, no.
Yes, when you're talking about typical electronically balanced inputs. Transformers are a whole other matter. A good transformer can give you good common-mode rejection even when driven from a wholly unbalanced source due to their incredibly high common-mode input impedance.
It's precisely that characteristic of transformers that Bill was looking to emulate with his inGenius circuit that he licensed to THAT Corp.
se
The Audio Guild
Old 5th March 2013, 05:07 PM   #36300
john curl's Avatar
If you generate a 'problem' that does not really exist, and then 'fix' the problem with added circuitry, upping the build cost 4 times, is it really worth it?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
