The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 27th February 2013, 07:45 PM   #35981
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by simon7000 View Post
If the issue of TIM is well understood, then one could calculate for any given design, how much would be present and use that in design trade-offs. ES
Yes but it is just a subset of general large signal limitations of amplifiers which is/was understood. You know slew as in slewing a coastal gun in WW2. An unnecessary extra acronym made up by the audio community.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 27th February 2013, 07:59 PM   #35982
simon7000 is offline simon7000  United States
The information added when the phrase TIM got invented was the issue not just of slew rate but gain (or transconductance) also counted.
When doing the classic control loop for gun control undershoot and overshoot were big issues. Nyquist gets the credit for that bit of math and increased understanding. Those are stability issues.
What in my OPINION was new was that with identical gain bandwidth products, amplifiers could produce internal distortion if the gain was too high and the bandwidth (or slew rate) too low. (Implying that increasing the gain of a circuit without increasing the bandwidth might not result in decreased distortion... under some transient conditions.)
This added to the knowledge of the large signal/small signal bandwidth (Slew rate) which came from the problems with higher speeds and larger swings on triangle waves.
It is a fine point of distinction.
Old 27th February 2013, 08:46 PM   #35983
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Bandwidth is (unless noted otherwise) a small-signal spec, slew rate is a large signal spec.
If you make sure your amp can handle the max signal amplitude and rise time it will enconter in normal use, there's no TIM or slew rate limitations. Straightforward engineering.
I cut my teeth, slew-rate wise, on Bofors 40L70 air defense guns.
We build an interface to connect these guns to a digital air defense processor. We learned very quickly that lower slew rate without overshoot was faster than high slewrate with a lot of overshoot, especially if it is you against a heavily armed jet fighter...
Absolutely the same as in electronics, replacing mechanical properties with capacitance, power and acceleration.
Many people here know quite well how to explain it, and many did.
But then some time later somebody comes along who should know better but spreads the same old disinformation again. Makes one tired.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 27th February 2013, 09:26 PM   #35984
gpapag is offline gpapag  Greece
gpapag's Avatar
jan
These guns ruined my ears
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 27th February 2013, 09:31 PM   #35985
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
You can't be that old George! You would have to be in your 90's at least I would think.
Old 27th February 2013, 09:43 PM   #35986
bcarso is offline bcarso  United States
diyAudio Member RIP
I think my first encounter with slew as a verb and adjective was when I joined the Astronomy Dept., where it applied to the rapid motion and associated motors of a telescope. On the control paddle, there was a big toggle switch you had to throw in order to enable it, as of course inadvertent actuation would cause you to "lose everything" if in the middle of a specific observation.
I once arrived at the site of the Dept.'s Ojai Field Station telescope, perhaps for some equipment changeout or responding to another problem. I was unexpectedly met by the late George O. Abell and a cute co-ed, respectively academic director and participant in that year's version of the long-running Summer Science Program at the Thacher School, in which I'd been a student in 1965. Chitchat ensued, and I asked George if the rules for appearance at dinner had changed after so many years, i.e. did one still have to dress for dinner. No, he said, the rules haven't changed, and gesturing toward her, for dinner she'd have to take all of that off.
But George went on to say how timely my visit was, as he had just been demonstrating telescope slewing and the protective limit switches in right ascension and declination. He learned that his recollection of limit switches in declination was faulty as he had slewed the tube into a grinding halt against the fork, thoroughly jammed.
Old 27th February 2013, 09:51 PM   #35987
Jan,
We are talking, but I don't think we are communicating.
If I have an amplifier with a gain of 100 at 1,000 hz. and another with a gain of 1000 at 100 hz. They both can be rated as having the same gain bandwidth. If they both have a thd of 1% at 500 hz, must they have the same TIM?
ES
Old 27th February 2013, 10:50 PM   #35988
Jan,
ES
The use of transient in that term is inaccurate, the input transfer function is there for contiuous time signals. The tanh shape for an undegenerated bipolar is directly related to the total current i.e. when at max there is the onset of hard slew. R.D. Thornton and J.K. Roberge at M.I.T were teaching it this way in 1969, Barrie Gilbert was already preaching from this pulpit in 1968 and before.
Old 27th February 2013, 11:00 PM   #35989
diyAudio Member RIP
And Tek and others were figuring out some ingenious ways around the limitations of tanh, as it were, mostly applied to global-feedback-free 'scope amps.
Old 27th February 2013, 11:06 PM   #35990
Esperado is offline Esperado  France
Banned
As you don't provide the transition frequency of each amp (or open-loop gain), this question cannot be answered.
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
