The Lounge A place to talk about almost anything but politics and religion.
Old 23rd February 2013, 08:01 PM   #35791
Esperado is offline Esperado  France
Banned
Originally Posted by john curl View Post
Richard, I just talked to Jack Bybee about his former project with the government. He quoted 16 billion dollars for that project...
That is what made silicon valley so powerful and advanced in those days. You know: MONEY!
The bigger it is, the easier it goes down.
How much it would cost to send back J. B.... on Mars with a quantum powered engine ?
I would prefer we talk about combinations of Jfets, indeed.
Old 24th February 2013, 02:08 AM   #35792
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Originally Posted by qusp View Post
interfet?
No, Moxtek Optics X-Ray Products- Optics, X-ray Windows, X-ray Detectorcs, Ultra-low Noise JFETs, X-ray Sources
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th February 2013, 05:01 AM   #35793
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
$16 billion for a 0.02 ohm resistor? And I thought $600 hammers and toilet seats were bad.
se
The Audio Guild
Old 24th February 2013, 10:55 AM   #35794
Max Headroom is online now Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Default Research And Development......
Originally Posted by Steve Eddy View Post
......$16 billion for a 0.02 ohm resistor? And I thought $600 hammers and toilet seats were bad. se
I was given one yesterday....some hammers are priceless.........
Dan.
Old 24th February 2013, 11:09 AM   #35795
qusp is offline qusp  Australia
qusp's Avatar
The subject that I wanted to talk about is:
Using combinations of Jfets, with other parts, to make 'super parts' that may have even once been made, but it might be cheaper to series and-or parallel devices and get similar results. This concept goes back more than 40 years to the FETRON which was a vacuum tube replacement, composed of a low input capacitance jfet cascoded with a 200-400V jfet (available at the time) for the voltage holdoff. This was originally used to replace real vacuum tubes in VTVM's made by a number of companies.
Today, we might use a MOSFET, instead of the high voltage jfet to get similar results. Heck, today we could make a solid state direct drive for STAX phones with a dual jfet cascoded by a pair of 800V mosfets, and get pretty good results. There are more combinations that we could talk about.
yep, I was thinking about that the other day re stax, was actually thinking of a direct digital USB->DSD->Gate driver->LDMOS RF fet STAX amp, but was reminded that most or at least many of these Fets have significant Ciss/Coss and with the ES driver being so low impedance top end distortion is an issue. thats not to say its not doable, but many of the new higher voltage fets are higher capacitance than desirable for such things.
thanks, interesting, nice parts but woah! did you tell them to go jump or are you getting some? if thats what they charge for the wire-bondable parts, what do they charge for the packaged ones?
se
its getting more and more ridiculous, guess he had to adjust the amount for inflation so it still sounded very impressive.
John, your friend is having a laugh
Old 24th February 2013, 01:32 PM   #35796
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Add some extra zeros, and Mr Bybee might have been just the right man for the SDI job in the early '80s.
("the Bigger it is", speaking of throwing Gobs of Meuney at General-D, and silicon valley, for a Limp Phal..anx ciws : USS Stark)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 24th February 2013, 02:44 PM   #35797
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
I don't know about $16 billion dollar programs in a military research and development but I do understand the $600.00 toiler seat or something like it. Until you see all the documentation and layers of inspection required to produce a part for an aerospace application you don't have any idea how expensive it is to actually produce some of these parts. Specialized tooling using specific materials with exacting quality control do not come cheap. I have had to estimate the cost to produce and bid on open government military projects. What often would catch you off guard was the particular material that was specified to produce a part. Recreating a part that has not been made in years does not mean that you can use a new modern material to produce that part. I have had to get quotations for producing a composite part that would require the use of a particular composite prepreg material. The part may require as little as one or two yards of material but you have to have the original producer of the material make a run of that material to use. Now you are purchasing a minimum of 100 yards of material at a cost of 20 to 30 thousand dollars and up, it is something that may not have been produced for 20 or 30 years and you have to pay to play. There is no old material, it is obsolete or out of date. You can not substitute a new material without going through a complete re-qualification of the part. This could take forever to do and cost more than producing the part with the expensive special order material. There is just no way to lower the cost and meet the requirements. I also was in the position to have to reproduce tooling that was no longer available for production of a part. Having to go all the way back to the original mylar drawings to reproduce a set of tools to make a one off part for an older plane sitting on the ground because somebody drove over an access door with a forklift and the plane cannot fly without the part. I have done that where we called it AOG, aircraft on the ground. Or when I had to reproduce a part for a B52 bomber that hadn't been made in years, Boeing will tell the government to go pound sand, buy a new plane, but someone has to service those planes. I personally built over 200 sets of tooling for KC135 planes for internal and external aluminum bonded panels. That cost somebody lots of money to keep those planes flying around the world.
On a separate track I was talking to a friend the other day and he was telling me about the topology of the old Spectra Sonics amplifiers of the 70's. He was telling me that in that amplifier that the amplifier was built with a unique circuitry. Instead of a differential input pair of transistors the amplifier was built with a differential output. I assume it could have also had the differential input besides the output but don't know. Could somebody comment on that, how that is accomplished and why there aren't more amplifiers with the outputs done this way? I assumed from the conversation that the amplifier was a mono channel card, not a stereo output.
Old 24th February 2013, 02:47 PM   #35798
It doesn't look like it could go into a product, but it still might be the only thing for a research project. They have one set up with a feedback cap (.03pF) and reset switch for use as a charge amp. To be fair these are pretty special and even require special bonding to accommodate the tiny geometry.
Old 24th February 2013, 02:52 PM   #35799
On Hiatus
SY's Avatar
I have some personal knowledge there. The $600 pricetag included amortization of the tooling.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th February 2013, 03:04 PM   #35800
qusp's Avatar
oh I agree I had a good read of the datasheets, I briefly started to convince myself I needed some of the 4 lead high IDSS parts for a cost no object IV stage (I dont have access to wirebonding on parts I could lose inside a teacup)
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
