The Lounge A place to talk about almost anything but politics and religion.
Old 22nd February 2013, 04:42 PM   #35711
john curl is offline john curl  United States
john curl's Avatar
WOW! Insulted again! '-)
Here I go out of my way to be objective, fair, and give experience, and still I am attacked.
I did learn something this week that I consider important.
I think that I mentioned that I found a new rock station that sounded great with my old Sony Walkman and headphones. Unfortunately, I found that on my big system, my computer system, or even my car radio, it was pretty darn marginal. I still love the music, but hi fi is not what these stations are broadcasting (most of the rock stations), and it actually sounds better without any highs or even high fidelity playback.
No wonder, Esperado, you show a distaste for really hi fi reproduction. I bet that your horn midrange limits the highs as well. What about it?
"Condemnation without Examination is Prejudice"
Old 22nd February 2013, 05:01 PM   #35712
Esperado is offline Esperado  France
Banned
My system is fine, thank-you. and i would not exchange-it for your Wilson monsters for an empire.
Considering your age, and what i suppose your ear's ability to listen to treble, let-me smile. And if i mistake about this, please, offer your body to the science !
And about hi-fi and engineering,, you are just like those people which advice people with a cancer to stop the chemotherapy and cure themselves with plants. It is simply unworthy.
Old 22nd February 2013, 05:04 PM   #35713
john curl's Avatar
For you technically inclined: Most people realize that almost all fuses are non-linear. The distortion producing behavior of fuses is secondary to the strict requirements they most conform to, so I suspect that most typical fuses are made of some sort of alloy that may even be more nonlinear that a what simple metal would be, because this would make fuses more 'ideal' for typical operation.
What do we know about fuses over long term experience? Well, many amps or loudspeakers used to have a fuse, in order to offer protection for the speaker, but sometimes, even the amp. This added nonlinearity to the audio signal, BUT it is difficult to easily measure the magnitude of the nonlinearity, because as the fuse material averages its resistance fairly well, unless you are testing with music or speech, the continuous tone will settle to an average and not show much. We have known this for over 40 years. We also found that, IF we could use a Slow Blow fuse, we would have more overall linearity in this application.
Today we rarely use speaker fuses, but we still use fuses in the power supply rails and ALWAYS in front of a transformer (unless the transformer is internally fused).
Our experience with this is that IF we can replace fuses with circuit breakers, either thermal or magnetic, we get better overall performance. My best amp designs use circuit breakers, but where we can't, we have recommended premium fuses to serious audiophiles for use in the JC-1 power amp, with some success.
Old 22nd February 2013, 05:21 PM   #35714
john curl's Avatar
Wilson WATT's monsters? Maybe pip-squeaks! '-)
Old 22nd February 2013, 05:40 PM   #35715
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Then quit making excuses and test with music.
Audio DiffMaker
se
The Audio Guild
Old 22nd February 2013, 05:41 PM   #35716
john curl's Avatar
Let's also up up the differences between the speaker system that I use today, and the one that Esperado uses today. Both can be very good.
I use 'essentially' a 3 way direct radiator (WATT with sub-woofer) with a very well constructed loudspeaker cabinet, better than 99% of them out there.
Esperado is using a midrange horn, with a direct radiator woofer (I presume). Now, does he add a tweeter, or not? This is an important question, because all the midrange horns that I know of, sharply roll off within the upper band of the audio bandwidth.
Old 22nd February 2013, 05:43 PM   #35717
john curl's Avatar
Good idea, SE. Go for it.
Old 22nd February 2013, 05:54 PM   #35718
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
-- Excuse me Scott !
Thx-RNMarsh
Sorry, didn't think we had any art dealers here. The art world does put fashion audio to shame.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 22nd February 2013, 06:02 PM   #35719
For you technically inclined: Most people realize that almost all fuses are non-linear. .
Yes but not their selling point...
"Synergistic Research Quantum Fuses employ a custom alloy treated with 2,000,000 volts of electricity! SR Quantum Fuses significantly outperform all other high-end fuses on the market and are guaranteed to deliver a noticeable increase in sound staging, resolution and air thanks to a lower noise floor and blacker backgrounds."
How do you treat an alloy to 2M volts?
Old 22nd February 2013, 06:04 PM   #35720
Steve Eddy's Avatar
I'm not the one doing all the hand-waving and making all the claims. That's you, John.
But apparently it's much easier to just weasel out and continue the hand-waving instead of actually doing something.
As my grandfather used to say, "I see a lot of choppin' but no chips flyin'."
se
The Audio Guild
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
