The Lounge A place to talk about almost anything but politics and religion.
Old 13th February 2013, 05:45 PM   #34991
Esperado is offline Esperado  France
Banned
Originally Posted by john curl View Post
Are you telling us that 'subjectively', you find higher slew rate better?
Why can't I say then, that 'subjectively' I find that open loop operation better?
Is your 'subjectively' better than mine? If so, how?
I had previously said that feedback and open-loop topologies are TWO different ways to reach the same goals, and even defended your choices.
And i just pointed than WITH FEEDBACK, i prefer high slew-rate and that is not a concern with open loop...What the hell ?
Why do you read everything in such a paranoid way ?
Old 13th February 2013, 05:48 PM   #34992
john curl is offline john curl  United States
john curl's Avatar
Marce, I do audio design for an audio public. We use both discrete and SMD in our designs. I have little against SMD, except that it tends to exclude QUALITY CAPS and sometimes, resistors. We discuss the problems, all the time.
"Condemnation without Examination is Prejudice"
Old 13th February 2013, 05:50 PM   #34993
john curl's Avatar
Esperado, IF you actually looked into what you are selecting, you would find that you are PROBABLY going for the higher quiescent version of the same op amp. Slew is just secondary to open loop linearity that you get with higher quiescent current. Please study up, and don't throw some cheap 60's mid fi amp at me, as an excellent example of design.
Old 13th February 2013, 05:50 PM   #34994
PMA is offline PMA  Europe
PMA's Avatar
It is close to useless to waste time here, in this thread.
Old 13th February 2013, 05:55 PM   #34995
marce is offline marce  United Kingdom
I love the bottom terminated devices, makes handling the heat on a populated PCB much easier, and as Scott has pointed out, you would be suprised what power densities you can achieve, even the new FET packages are more efficient that the old TO style PTH devices, mount them directly onto a ceramic heat sink with the copper pattern printed on the heat sink so you solder the device to said heatsink, and you get some realy realy low thermal resistance, so the device works optimaly, and with further implementation you can embed heat pipes into the heatsink and achieve some very high power, high slew rate RF designs in quite compact spaces...
I also do audio though mainly either professional gear, or communication systems, the parts are out there...
Old 13th February 2013, 05:55 PM   #34996
Banned
Please provide your 'excellent example of design amp' done in 70. We will simulate and compare.
Your MID-FI pretentious argue is boring.
Old 13th February 2013, 05:56 PM   #34997
john curl's Avatar
No, PMA, think about people other than yourself: They NEED TO KNOW. Vague criticisms need to be explained away. In any case, for Esperado's sake I will AGAIN post my main audio paper that I did in the 1970's without any other author:
Old 13th February 2013, 06:04 PM   #34998
john curl's Avatar
Sorry, Esperado, my early schematics were burned up in the 91 firestorm. However, at the time, 1969, I designed a 2000W amp that was a complementary differential 4 quadrant bridge amp with 50V/50A output for Ampex Research. This was then converted to a floating balanced current source for motor drive operation.
The circuit you showed was typical of what was in 'Wireless World' at that time. My goodness, you have no idea what we were working on in those days.
BOOTSTRAPED driver stage! Quasi-complementary output. How quaint! '-)
Old 13th February 2013, 06:10 PM   #34999
Banned
And what ? So, you agree with what i said, and we yet knew that at this time. I do not understand your position. Arguing with somebody who think the same way than you because some shadow on your glory and fame ?
Old 13th February 2013, 06:12 PM   #35000
Banned
Slew-rate ?
i'm not impressed by power, i had some very poor sounding Crown power amps, and i thought we were talking about audio and slew-rate effects
The circuit you showed was typical of what was in 'Wireless World' at that time..
What was original at this time was the use of fast devices, for slew-rate, as i said. Everybody was using poor 2N3055 at this time.
This amp was using a stabilized supply with protection, and switched resistance arrays for volume and tone controls, like all mid-fi, isn't it ?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
