The Lounge A place to talk about almost anything but politics and religion.
Old 8th February 2013, 04:13 PM   #34461
DF96 is offline DF96  England
If the device can distinguish signal from noise in the current passing through it then it must contain a Maxwell demon. Given the Nasa connection, does that mean that it is not military tech but alien tech?
Old 8th February 2013, 04:17 PM   #34462
john curl is offline john curl  United States
john curl's Avatar
Max, you might have a reasonable approach. Diffmaker might work in this case. I might be able to set it up with my new PC and its high quality Sound Module, that I haven't even fired up, because I have no immediate use for it.
I have been waiting for a better instrument than my HP 3563, which is an SRS, than many of us have seen demonstrated at AES, but I might be able to do it with what I have. See how things get done? I'm just a tired old man, but I can be inspired too!
"Condemnation without Examination is Prejudice"
Old 8th February 2013, 04:21 PM   #34463
On Hiatus
SY's Avatar
Originally Posted by Max Headroom View Post
Ok some questions...
- Who participating in this discussion thread have direct experience of BQP.
- Of those, has anybody done a 'Diffmaker" comparison, and what was the magnitude wrt the original signal of the derived difference.
- Ditto, what was the nature of the sound of the difference signal
In order:
1. Me.
2. Null to the same level as a 30 m-ohm resistor, i.e., better than 120dBFS. I may have even posted the files at some point. I did send them to someone who was a "believer," and he publicly confirmed that they were indistinguishable.
3. Random noise in both cases, same as any loopback.
In every single measurement, the results were indistinguishable from a cheap resistor. It's easy to find lots of positive "reviews" of any placebo (not just in audio) that has a good story behind it.
Fraud or performance art, take your pick.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th February 2013, 04:25 PM   #34464
On Hiatus
SY's Avatar
Originally Posted by john curl View Post
Poor old Dr. Hawksford, he 'messed up' too, according to you, JN.
Not just according to jn. You left out all the other people (including the referees who rejected it from the same engineering journals that publish other papers of his that aren't obviously wrong) who found the major flaws.
Old 8th February 2013, 04:28 PM   #34465
PMA is offline PMA  Europe
PMA's Avatar
That sort of AC 'clipping' appears to be an artifact of the display. I can get the SAME sort of 'clipping' from one of my early graphic calculators when showing a sine wave. Get real guys!
Only usual power mains network distortion. Measured thru 1:2 voltage divider.
Old 8th February 2013, 04:31 PM   #34466
john curl's Avatar
Really? I will have to talk to Malcolm about this, next time I see him. The last time we spoke about this, he was adamant that he was correct.
Old 8th February 2013, 04:32 PM   #34467
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Default Dither Ain't Dither....
'Signal' is never plain signal...it always signal PLUS noise PLUS distortions (plural) PLUS distorted signal PLUS distorted noise PLUS distorted distortions (plural)...and so on...IOW typically a sorry mess.
Changing the nature of the system noise will exponentially change the nature of the final audio resultant.
Dither is touted as a cure all, so how come differing dithering sounds so subjectively different ???...Hint, try mixdowns on Cool Edit for example using differing dithering...IME the resultants are profoundly subjectively different !.
Dan.
Old 8th February 2013, 04:34 PM   #34468
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Maybe they live in the nanotubes. Max, they go to great effort to emphasize the causally impossible separation of signal and noise after the fact. I've posted pictures of the horrible 1/f noise on a typical LP, lets see the removal of this with no effect on the low frequency musical content.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 8th February 2013, 04:41 PM   #34469
KMossman is offline KMossman  China
KMossman's Avatar
Send a message via Yahoo to KMossman John Curl's Blowtorch preamplifier part II
terrible pun
wish I thought of it
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies]
Old 8th February 2013, 04:50 PM   #34470
On Hiatus
SY's Avatar
If you change the spectral distribution of a noise floor, it can certainly sound different. Nothing remarkable about that, this is why you have those options in sound editing.
Dither is not a "cure all," it is a cure for a particular disease- quantization. And indeed, even with different dither types, quantization distortion disappears.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
