The Lounge A place to talk about almost anything but politics and religion.
Old 4th February 2013, 05:27 PM   #34161
elektroj is offline elektroj  Europe
Originally Posted by Esperado View Post
OPA with offset.
Care to show it how it will work?
With 32 bits, you can attenuate by 60db without any audible artifacts. What the hell ?
Indeed ..
http://www.jamminpower.com/PDF/48-bit Audio.pdf
Old 4th February 2013, 05:36 PM   #34162
PMA is offline PMA  Europe
PMA's Avatar
Anyone ever seen true 32 bits without errors, skip codes, glitches and uncorrelated spuriae? Real worls is somewhere at 20 bits, if excellent.
Old 4th February 2013, 05:37 PM   #34163
Esperado is offline Esperado  France
Banned
Nothing complicated: Applying a +2.5V *low noise* reference to the + input of the OPA (gain 1) , while you enter your signal to the -input.
Old 4th February 2013, 05:39 PM   #34164
PMA's Avatar
.... yes, low swing (<5Vpp)
Old 4th February 2013, 05:44 PM   #34165
Banned
PMA, this 32 bits is not sampling rate, 24 bits is large enough. It is precision for calculation. Then rounded for 24 bits with dithering.
Anyway, i do not know so much AD converters in 32 bits, and i worry what kind of previous analog stage able to use all the bits, indeed :-)
Old 4th February 2013, 05:48 PM   #34166
On Hiatus
SY's Avatar
If 32 bit calculation is problematic, your computer won't work.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th February 2013, 05:54 PM   #34167
Waly is offline Waly  Umm al-Qaiwan
Waly's Avatar
For the reasons you have just described, I built a measuring amplifier with gain 40dB to be able to measure noise level of preamplifiers and make FFT analysis (noise level which is normally below common audio measuring system threshold) and to be able to measure at low output level. My SW computes unweighted integral noise in 20Hz - 20kHz band, so no tricky "noise bottom" like -150dB etc, which depends on bin width (number of samples in FFT, sampling frequency and possibly averaging as well). Noise of the measuring amp is attached. So I amplify the preamp output by 40dB, measure noise and ten subtract -40dB to get preamp's noise. I also measure distortion, at about 10 - 20mVrms of preamp output voltage. I have not measured any increase of harmonic distortion at low signal output level, but found differeces in noise of preamplifiers and its spectra.
With this method, I can measure noise level down to -126dB/ref 1Vrms (20Hz - 20kHz, unweighted). The best preamp I measured had noise -115dB/1Vrms unweighted, 20Hz - 20kHz. The gain of that preamp was 14dB.
I have to admit I am still in the dark with what exactly you are measuring. In particular the lack of 1/f noise (increasing by 10dB/decade with decreasing frequency) is intriguing.
What are the units on the Y axis? dB ref. 2V of what? It's certainly not the standard nV/rtHz. Could you draw the noise of a 1Kohm resistor on the same graph?
Old 4th February 2013, 06:00 PM   #34168
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Sy,
Don't we just daisy chain a bunch of 8086 chip until we get to 64 bits.........
Old 4th February 2013, 06:13 PM   #34169
bcarso is offline bcarso  United States
diyAudio Member RIP
What's often interesting about datasheets is what is left out. After that, what the conditions of measurement and specification are.
I miss the characteristic curves in the old databooks for various transistor "processes". But I'd conjecture that people were referring to them and holding the manufacturer to them, rather than the guaranteed specifications for a particular part selected from that process.
Old 4th February 2013, 06:14 PM   #34170
On Hiatus
SY's Avatar
I use an abacus. None of these newfangled calculational methods.
Just the other day, I was having lunch with some of my colleagues, and we were talking at a level that people here wouldn't understand. There were questions about wire and bead materials and how they can impact the accuracy of accounting. But if you're happy with wood and steel, more power to you. We selected jade and nichrome after extensive testing, but that's the difference between a Bentley and a Yugo. Works for me!
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
